Thanks for the reply.
My linux is 64bit and i have an intel processor. Just a side note, installing cura 3.3.1 from the repository works but iam hoping to get this newer version running.
I think i found the log file:
QuoteFatal Python error: Segmentation fault
Thread 0x00007f8add716700 (most recent call first):
File "/build/env/4.8/inst/lib/python3.5/threading.py", line 293 in wait
File "/build/env/4.8/inst/lib/python3.5/threading.py", line 424 in acquire
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/JobQueue.py", line 98 in _nextJob
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/JobQueue.py", line 123 in run
File "/build/env/4.8/inst/lib/python3.5/threading.py", line 914 in _bootstrap_inner
File "/build/env/4.8/inst/lib/python3.5/threading.py", line 882 in _bootstrapThread 0x00007f8addf17700 (most recent call first):
File "/build/env/4.8/inst/lib/python3.5/threading.py", line 882 in _bootstrapCurrent thread 0x00007f8b06630740 (most recent call first):
File "/build/4.8/build/inst/lib/python3.5/site-packages/cura/UI/CuraSplashScreen.py", line 73 in drawContents
File "/build/4.8/build/inst/lib/python3.5/site-packages/cura/UI/CuraSplashScreen.py", line 41 in show
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/Qt/QtApplication.py", line 536 in createSplash
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/Qt/QtApplication.py", line 543 in showSplashMessage
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/Qt/QtApplication.py", line 190 in startSplashWindowPhase
File "/build/4.8/build/inst/lib/python3.5/site-packages/cura/CuraApplication.py", line 474 in startSplashWindowPhase
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/Application.py", line 239 in run
File "/build/4.8/build/inst/lib/python3.5/site-packages/UM/Qt/QtApplication.py", line 341 in run
File "/build/4.8/build/inst/lib/python3.5/site-packages/cura/CuraApplication.py", line 780 in run
File "/build/4.8/build/inst/bin/cura", line 235 in <module>
File "<frozen importlib._bootstrap>", line 634 in _load_backward_compatible
File "<frozen importlib._bootstrap>", line 664 in _load_unlocked
File "<frozen importlib._bootstrap>", line 957 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 968 in _find_and_load
File "/build/env/4.8/inst/lib/python3.5/site-packages/cx_Freeze/initscripts/Console.py", line 21 in <module>
File "/build/env/4.8/inst/lib/python3.5/site-packages/cx_Freeze/initscripts/__startup__.py", line 12 in <module>
Edited by djquincy
gr5 2,206
I have Ubuntu Linux. Works fine for me. I do get a handful of errors like you but it seems to work fine. The key error is the "segmentation fault". I definitely don't get that!
Anyway please post the cura log file which will likely have much more information. For me it's in:
/home/gr5/.local/share/cura/master
There are software people who work on cura on this forum and with the log file they will know much more.
Is your Linux 64bit? I think that's a requirement. Also you need to have an x86 processor (intel or AMD). Not some cell phone chip or something. Not a chrome pad.
