Please post the EXACT ufp file that gets this error so I can look at line 146. If the file is gone then please post the ufp file the next time this happens.
Can you prove that it's the same olimex card? For example if you had configured the old one for your wifi network but not the new one yet the new one already knew about your network?
Usually if a vendor says they replaced something, they did.
gr5 2,195
I'm not 100% sure but I think it means the gcode file is corrupt (actually ufp file for S3).
If it only did this through USB then I'd say you've got a bad USB drive but if it also does it through network printing - still (check one more time if you haven't already since you got the printer back) then I'd say your flash memory on the olimex board is corrupt. I'd get a new one asap. Especially while still under warranty!
Another thing to try - upgrade the software to the latest firmware - this stresses the flash drive and moves files around and if it completely fails the upgrade then that's confirmation. Or if you are lucky now files printed over the network are in a new position.
If you know linux and you have the older firmware you could create a few gigabytes of junk data on there such that new files printing over the network will go into a different location on the internal olimex flash drive as these failures tend to be localized (in just a few spots of the flash) in my experience. But the newer S3 firmwares I think disable the ability to ssh into the printer and do this kind of thing unless you have the olimex serial cable.
Anyway, if it's still under warranty when you started getting these errors, have the reseller give you a new olimex board. I've heard the claim that these types of errors are rare (corrupted flash) which really surprises me as I've met a few people with the issue (different issue from yours). So each case like this needs to have some attention placed on it.
SeeDiph 0
Still getting the error even with the usb removed. Supposedly they swapped out the board when I sent it in. So bizarre...
