Basically we have all seen times where the first layer isn't printing quite right, either too smooshed or maybe a little bit gappy. This can occur even after leveling your bed - especially if you switch between materials very often. Right now you see a lot of people talking about reaching in and tweaking the bed leveling screws to either lower or raise the bed while it is printing the first layer. That works but is is not accurate and then after the print is done you have to manually level your bed again because you probably did not turn all three knobs by the exact same amount.
Live Z adjustment does the exact same thing as turning the knobs but it does it in a controlled way across the entire surface. So as your watching that all critical first layer print you can make those minute adjustments to get it perfect without messing up your bed leveling. It is basically the Z offset setting in Cura, but you can do it while the printer is printing so you can see the results as you make the adjustments.
2
Dim3nsioneer 557
What would be the use case for such a feature?
