Hi Nallath!
I have a 3dsolex block for the nozzle. Kinda like an olsson block. Same principle.
Bad linear bearings on Z axis makes it tougher to move up and down. it can get somewhat stuck at different places when moving bed up and down ny hand. Hence missing layer.
I would need a video to show the vibration. Sorry to say I don´t have one. Here´s a vide on someone else (different brand printer) bud the issue is similar to this. not as much as in the vid but still..
I´m not the only one with this problem. https://www.thingiverse.com/thing:2007717
nallath 1,125
Since you have an ulitmaker 2, you also have the "old" style hotend and feeder. Those have been fixed with the UM2+. You can just get a upgrade kit for that.
This will fix the underextruding and missing layers. I really don't see why / how a linear bearing or Z nut would fix the missing layers. They are more often caused by under extrusion.
As for the bed vibrating; Do you have an image of that? I've never had any issues with that.
