I print TPU on one of my Ender 3s all the time. Took me quite some time to get the settings right. I also have a direct drive one which needs some different settings, but is also working great now.
I use a retrac distance of 2.5mm with a speed of 50mm/s.
I also enabled z hop with a height of 0.4 mm to avoid any "antennas".
All printing speeds are set to 20mm/s with a hot end on 225°C.
1
geert_2 553
The cause is filament leaking from the nozzle while traveling through the air, due to the pressure in the nozzle not immediately dropping to zero. Especially with flexible, compressible filament. This leaking causes a sort of "insect antennas": the drop on the nozzle is deposited on the edge of the next wall the nozzle encounters. And then on the next layer, it is deposited on the previous drop, and so on, creating these antennas. However, you have a peculiar form of it.
Rubbery materials (when molten) like PET also have this tendency.
Maybe print still slower, cooler and in thinner layers? So there is very little pressure build-up in the nozzle and bowden tube? And the filament leaks less due to being cooler? Printers with bowden tube are more prone to this obviously than direct drive printers, due to their long feeding traject under pressure.
A close-up of these "insect antennas":
For comparison: ruler next to the item with antennas is in mm and cm.
edankleef 1
Hi geert_2,
Thanks a lot for getting back to me. The "insect antennas" from your pictures are indeed very similar to mine!
The Sovol SV01 printer has a direct drive extruder and should therefore have less pressure issues with TPU.
I have tried printing at 220°C instead of 230°C and 15mm/s instead 27mm/s printing speed. The results are unfortunately exactly the same:
Could there be any other reason you can think of?
Best,
Ewald
