1) What Torgeir said about the steps/mm.
2) The bondtech is skipping? Really? Is the tension half way up the scale as described here? http://www.bondtech.se/wp-content/uploads/2018/08/Bondtech-DDG-Ultimaker-V1.0.1.pdf
Is it possible the filament is slipping through the feeder and the stepper isn't actually going backwards?
3) When you use the i2k you should cut off part of the teflon part by the same amount. So if the i2k is 1mm thick then slice off 1mm from the teflon part. If you don't do this - particularly on the "plus" series printers like yours, that aluminum spacer can't compress and you have MUCH too much pressure on the teflon and it tightens/pinches/grips around the filament.
4) Is your teflon part new or old. You say it is "PTK" but I'm not sure what that means. There is the Ultimaker spacer and the 3dsolex spacer - both are great but need to be replaced regularly (like every 200 to 500 hours of printing).
The easiest way to diagnose is to put the filament half way down the bowden. Have the extruder move it forward with MOVE command and then fight that with your hand by pulling down on the filament just below the feeder. You should be able to pull 5kg or 10 pounds of force without the feeder skipping. If it skips then something is wrong with the extruder.
If it doesn't skip then it's the print head. I suspect the print head but it could be either.
- 1
Torgeir 248
Hi @my3DBr
How many E-steps are you using with this setup?
They advice E-steps for an UM2+ to be "311", but this is for an 1.8 deg/step motor. (200 step/360 deg)
Found here:
https://www.bondtech.se/product/ddg-extruder/
As you have the old stepper (from UM2E) that's 0.9 deg/Step. (400 step/360 deg)
According to this, -you'll need to double the number of steps by 2, I.E. E=2*311E=622 E-step, for your setup.
If the E-step setting is too high, the stepper may miss step.
Also, if the current setting is too low you may see missed step.
Normal current setting for the feeder stepper motor (E1 or E2) is 1200 mA.
Thanks
Torgeir
