Here is the thread if you want to discuss features, problems or whatever 🙂
On 1/28/2022 at 3:53 AM, Super_paulie said:defo going to look into that Smithy, just need time when the printer isnt in use! its pretty much 24/7 in here with really long jobs.
It looks great though. Most of those commands should really be in a "developer/pro mode" within the firmware, especially the bed levelling as our bed never moves and the hot end wrecks the kapton. Im defiantly gunna give the tuner a go hopefully this afternoon.
What does this do in terms of warranty on the machine...?
Full warranty policy here: https://support.ultimaker.com/hc/en-us/articles/360011627400-Ultimaker-S-line-warranty
This would probably fall into the third party section under conditions if I was going to hazard a guess.
Smithy 1,088
Good question, I would say it should be no problem in case something bad happens, but I am not an expert on the warranty topic. You can always revert the changes you did. When you i.e. enable the active leveling again, then the file looks like before you have changed something.
To disable the bed leveling, the tool changes one value directly in the source code of the firmware. To change the cool down procedure, the tool modifies the so called safe temperature from 60 to something else.
Basically it is safe to use this tool, it uses methods we found out over the time and a lot of users are using these methods already. The tool just makes it easier for users which are not so used to use ssh and a linux command line.
A firmware update usually overwrites these changes again, so after an update you have to do the changes again.
