I second this issue. Use an environment variable CURA_WORKDIR=xxx, or recent_dir (vs recent_files).
Every time I do any kind of file access (open, save, etc) , I have to navigate all over the place. It also does'nt remember the filename I opened, so saving a slice requires navigating and naming. I know that sounds petty, Just a feature request.
ahoeben 1,955
Cura normally stores the last location you opened a 3d model from. However, Cura uses the file dialog provided by the OS, and if that file dialog does not accept the stored last location, then (re)setting that location in cura.cfg will likely not do you any good. So in short: there is no way to change that (other than fixing this slight incompatibility between Cura and your OS)
