There are always some discussions about Infill density versus print time and part strength . An interesting video :
Not sure that 100% give the best result, Layer Height , and Wall Number are also important. And one point I think : Linear Infill is any way a better choice for stress distribution and adhesion between layers.
Cuq 202
Strange Infill Method :
Infill Density = 99%
Infill Pattern = Concentric
Connect Infill Polygons = On
Is it realy necessar ?
rachael7 74
Good eye! Yes, I believe it is necessary in this case. This particular example is a highly stressed functional part, subject to both steady and impulse forces, so it needs a lot of strength. I've oriented the layers and infill to maximize strength in the most highly loaded directions. It is actually 100% infill though, I'm not sure why Cura renders it with gaps between the lines; I know Cura renders it that way when the flow rate is less than 100%, but I don't recall if that was the case in this particular profile or not. You do bring up a good point though, that I am running 100% infill, which is somewhat less common. Perhaps my infill flow rate is a touch high and areas with more infill, the excess material builds up and bulges out a wall. The bulge would end up on whichever side was printed last, I would think, since the material would more easily push to the warmer side. Interesting. Thanks for the feedback!
