Yes sorry I meant material station, both machines worked without the station however we need them to work with them. I was fiddling around with the newer machine yesterday and have got it to print for about 10 minutes however print core 1 inevitably blocks up. I tried cleaning then re-running the machine twice however am now receiving a new issue with print core one. the cabinet believes that the is no material in the spool, I have a new and keep getting either that message or a message to load material into print core one, which with material station is seemingly impossible.
gr5 2,094
"with cabinets". Does that mean you have the material station because if so then that complicates things a lot.
If not then there is a quick test you can do. I don't know if this works with the MS or not but it works without the MS. Go into the middle menu on the left and then click on the upper area where they show the filament types for left and right side. Pick one. Then click on the "..." in the upper right corner and choose "MOVE". Then retract the filament until you see it in the bowden and then move it forward a little (keeping so you can see the end of the filament) and fight the filament with one hand below the feeder while turning the dial to move the filament forwards. The feeder can pull up to about 15 pounds max. 10 pounds or 4kg of pulling power I would consider passing. 5 pounds of pulling power will print okay but I would consider that broken.
