Hi joatrash
This is a complete set, you must select it in Cura and dismantle. Then you can select different objects from the set and position on the platform. I would print all the objects in sequence. Then you can better see what is possible. Some objects must be correctly rotated and rearranged. And some objects require support material. Since there is a lot of preparatory work to ensure that everything is possible.
But you can print almost anything. The correct question should be:
Will it look good in the end?
Markus
IRobertI 520
The tall cylindrical piece will print just fine. I'd be more worried about the part with gears, that looks iffy. Could you print the gears separately perhaps so that it can lie flat on the bed? Then you could probably rotate the "case" for the gear to a less challenging position.
I'd probably also rotate the piece that is to the left of the tall cylinder, it looks sorta like the slide of a gun, so that it stands tall and on an angle (it looks like it has a flat surface on the back that is angled a little bit). That way you wont need any support at all for it.
Difficult to say more as it's a bit hard to judge the pieces on the pic alone.
