Bugs resolved since the Beta Release
- Introduced Balanced and Solid profiles for 1C extruders to UltiMaker Method X and Method XL
- Improved self-support for UltiMaker MethodX and MethodXL printers so the support extruder will not be used
- The prime tower is now always enabled when the second extruder is used for the MethodX and MethodXL printers
- Updated the default prime tower position so it doesn't prevent slicing for some printers
- Fixed an issue where raft layers were partially printed
- Slice information template variables were not available through start-end code formulas
- Resolved an issue with 100% support roof for tree support, contributed by @thomasrahm
- 1
Top Posters In This Topic
12
7
7
4
Popular Days
Feb 15
7
Feb 17
7
Dec 12
6
Dec 13
5
GregValiant 12 posts
gr5 7 posts
RunTime 7 posts
Cuq 4 posts
Popular Days
Feb 15 2024
Feb 17 2024
Dec 12 2023
Dec 13 2023
Popular Posts
LePaul
Yeah, I don't know where their testing is these days. Here's what I see on the download page. If they can't get that right, I may stick to 5.3.1 for bit longer 🙂
GregValiant
Computers are dumb, but they are superbly accurate. "Merge" operations in CAD are also called "boolean" operations and there are three: Union, Subtract, and Intersect. When you perform a Union
GregValiant
Unzip this script and place it into your Configuration Folder "scripts" sub-folder. It will be available in "Extensions | Modify Gcode" and then select "Add Cura Settings" from the list. It will
Posted Images
GregValiant 1,254
Is this a bug (or is it a test)?
link is to:
https://github.com/Ultimaker/Cura/releases/tag/5.6.0-beta.1
rather than:
Edited by GregValiantLink to post
LePaul 321
Dustin 130
Fixed.
