I read tuning in the acceleration behaviour in the notes of Cura 5.5 as some tuning in input shaping, but maybe that was not quite the way they did it..
Hi there,
From Cura ver. 5.5.0 they implemented some new functions into Cura, here is the actual issue:
Excerpt from Cura 5.5.0 text file.
"Enable Fluid Motion, Fluid Motion Shift Distance, Fluid Motions Small Distance, and Fluid Motion Angle are settings for printers with smooth motion planners like Klipper."
Thanks
Torgeir
Edited by Torgeir
Wrong entry.
S series does not have input shaping in the firmware at this time.
- 1
- 3 weeks later...
On 2/26/2024 at 10:59 AM, Dustin said:S series does not have input shaping in the firmware at this time.
I read somewhere that the S series (particularly S5) is using Marlin firmware.
I just updated my original Ender 3 firmware to Marlin 2.1.x and and tuned Input Shaping after printing the acceleration tower, and it practically completely fixed my ringing in my letters.
I wonder if it might be possible for the future for S5 to have input shaping? Or is it a complete rebuild of the firmware to make this happen? Input shaping is said to be the best thing in 3D printing for some time, and I agree, it really helped increase the quality of my Ender3 prints! Hopefully S series can implement this function too, regardless of any accelerometer, I can tune it manually if the feature is implemented 🙂
That would rebreathe life into some of these old S5 printers, because even with the visual setting my S5 still has ringing on letterings which would obviously benefit from input shaping.
My Ender3 has a 400x400 bed which is very heavy, and the input shaping was the only trick that helped slow the vibrations from that Y movement.
TL;DR, I would love to see input shaping on the S series printers, regardless if it requires a long time to tune and get it right.
- 2
13 hours ago, RaidenUltimaker said:I read somewhere that the S series (particularly S5) is using Marlin firmware.
It uses a fork of a very old version of Marlin as part of the firmware. It would be a LOT of work to rebase the changes that were made to the Ultimaker fork onto a more modern version of Marlin.
- 1
- 4 weeks later...
On 2/26/2024 at 8:59 AM, Dustin said:S series does not have input shaping in the firmware at this time.
At this time 😏....
The photo suffers more from JPG compression artifacts than what ringing is a case here. That being said, in fast printing one still see ringing artifacts, so I guess input shaping is not implemented yet.
ahoeben 1,951
Er... does the S3 support input shaping? That's new to me...
