I've repeatedly asked for references to 'Quality' to be removed from the Cura UI and quickprint settings names, because I think it's totally misleading. It implies that certain levels of settings are 'good' and others are 'bad', and that's simply not the case. It depends what you are printing. Some are faster, some are slower. Some are better able to reproduce finer details than others.
But it's wrong to think that thick layers = poor quality = bad to use, and thin layers = good quality = good to use. It's just not that simple.
gr5 1,968
No design problems.
But if you want higher quality than .05mm you should get a smaller nozzle first. The nozzle hole diameter is .4mm. The radius is therefore .2mm. You can't get good details in X/Y any better than .2mm without getting a smaller nozzle.
So there is not much point in going higher than around .06mm for Z axis. I never go thinner than .1mm.
Also I have a print that took about 40 hours at .1mm. If I went to .02mm layers it would take 200 hours or 8 days to print. More than a week! That's too long to tie up my printer.
