Surface looks a lot worse in Cura 14.03
wallan
  • Replies 96
  • Created
  • Last Reply
Top Posters In This Topic
Posted · Surface looks a lot worse in Cura 14.03
I use the TEST2 Version, but the Plugin TweakAtZ has no function. The parameter deletes after saving the gcode.
Thorsten
Please try to close and reopen Cura. If that doesn't help, please deactivate the TweakAtZ, close Cura and reopen it and reactivate the plugin...
TweakAtZ 3.1.1 does work with Cura 14.03-test2 in general, which of course does not exclude problems with a single installation...but for different reasons.
    Hey Daid,
    since the surface quality problems are a bit worriesome with the latest Cura, could you please release a fix? (like the TEST2 version as Cura 14.03.01). The surface in TEST1/2 looks fantastic.
    Pretty please :)
    downloaded "test 2" last night. I printed one of my self drawn models. with a very high resolution stl... and there where still artefacts and ugly bits due to super slow and "hopping" print speed... I am currently not at home but will try to post some pictures later....
    after a lot of experimenting I have found my problem.... it turns out that my stl output of solid works produced just too detailed stls... I selected a max stl deviation of 0.01mm (not a problem) and a max stl edge length of 0.3mm (big problem)...even straight lines get converted into very tiny segments of g code and this results in varying print speeds during printing an intended straight line.(very very ugly print results) ...for now results are fine we will see what the future brings.
    But what to do with already exported .stl files? Is there a way to simplify them afterwards? Maybe with Meshlab?
    no idea....i'm also a bit concerned about this, because the reason I set the resolution so high, was for me to simplify " gluing" stl files together in mesmixer...because of the insane number of triangles it was very easy to "boolean" the stuff together. so for me it would be nice if cura/um2 could easily handle this kind of detail....
    How does the 14.01 release do on those models? I have a few tweaks and stuff I can try. But in the end it's a careful balance between keeping the model detail and not generating too verbose GCode.
    sorry daid...i'm currently trying to manage my household...(four kids). will get back on this as soon as i find some time...
    No problem. Just report back on it when you have time, in the meantime I'll do some tests of my own.
    Hi everyone (Daid somewhat in particular)
    I have been playing around with some of the things mentionden above and found somthing interesting.
    When i was having trouble printing super high res stl, i saw that the inner contours sufferd much more speed variing issuses than the outer ones. (although the outer contours were stille very ugly).
    At first i thougt this made sense because of the higher speed i was printing the inner contour.
    Bur now i found out somthing else. When printing a shape like the posted picture, the outer contour (with no infill just testing) can be defined by 4 G-code commands, and one could think that would also apply for the innen contours. But if you look at the sample of my G-code, it is clear that this is not the case.... Funny thing is, when this object is placed alinged with, for example the x-axis, the outer and inner contour for each layer do consist of only four lines.
    Knipsel
    ;TYPE:WALL-OUTER
    G1 F840 X119.01 Y108.60 E8.52530
    G1 X116.52 Y117.88 E8.56142
    G1 X106.71 Y115.25 E8.59964
    G1 X109.19 Y105.97 E8.63575
    G0 F15000 X109.90 Y107.20
    ;LAYER:16
    G0 X109.28 Y107.19 Z1.21
    ;TYPE:WALL-INNER
    G1 F960 X109.47 Y106.47 E8.63856
    G1 X109.87 Y106.57 E8.64009
    G1 X110.35 Y106.70 E8.64198
    G1 X113.27 Y107.48 E8.65335
    G1 X113.76 Y107.61 E8.65524
    G1 X115.22 Y108.00 E8.66092
    G1 X115.70 Y108.13 E8.66281
    G1 X117.16 Y108.52 E8.66850
    G1 X117.65 Y108.65 E8.67039
    G1 X118.54 Y108.90 E8.67388
    G1 X116.26 Y117.40 E8.70699
    G1 X110.51 Y115.85 E8.72941
    G1 X109.53 Y115.59 E8.73320
    G1 X109.05 Y115.46 E8.73509
    G1 X107.59 Y115.07 E8.74077
    G1 X107.20 Y114.96 E8.74230
    G1 X107.45 Y114.01 E8.74600
    G1 X107.71 Y113.04 E8.74980
    G1 X109.02 Y108.16 E8.76880
    G1 X109.15 Y107.67 E8.77070
    G1 X109.28 Y107.19 E8.77259
    G0 F15000 X109.19 Y105.97
    ;TYPE:WALL-OUTER
    G1 F840 X119.03 Y108.61 E8.81092
    G1 X116.60 Y117.70 E8.84631
    G1 X116.55 Y117.89 E8.84704
    G1 X106.71 Y115.25 E8.88537
    G1 X109.19 Y105.97 E8.92148
    ;LAYER:17
    G0 X109.29 Y107.15 Z1.27
    ;TYPE:WALL-INNER
    G1 F960 X109.47 Y106.47 E8.92417
    G1 X109.87 Y106.57 E8.92570
    G1 X110.35 Y106.70 E8.92759
    G1 X113.27 Y107.48 E8.93896
    G1 X113.76 Y107.61 E8.94085
    G1 X115.22 Y108.00 E8.94653
    G1 X115.70 Y108.13 E8.94842
    G1 X117.16 Y108.52 E8.95410
    G1 X117.65 Y108.65 E8.95599
    G1 X118.57 Y108.90 E8.95961
    G1 X118.33 Y109.79 E8.96306
    G1 X118.21 Y110.28 E8.96495
    G1 X117.94 Y111.25 E8.96875
    G1 X117.81 Y111.74 E8.97065
    G1 X117.03 Y114.67 E8.98205
    G1 X116.90 Y115.15 E8.98395
    G1 X116.51 Y116.62 E8.98965
    G1 X116.38 Y117.10 E8.99154
    G1 X116.30 Y117.40 E8.99271
    G1 X112.97 Y116.51 E9.00568
    G1 X112.48 Y116.38 E9.00758
    G1 X111.51 Y116.12 E9.01137
    G1 X111.02 Y115.99 E9.01326
    G1 X109.56 Y115.60 E9.01894
    G1 X109.08 Y115.47 E9.02083
    G1 X107.20 Y114.96 E9.02815
    G1 X107.33 Y114.47 E9.03007
    G1 X107.46 Y113.98 E9.03197
    G1 X108.25 Y111.06 E9.04337
    G1 X108.37 Y110.57 E9.04527
    G1 X108.64 Y109.59 E9.04907
    G1 X108.77 Y109.11 E9.05097
    G1 X109.16 Y107.64 E9.05667
    G1 X109.29 Y107.15 E9.05857
    ;TYPE:WALL-OUTER
    and when placed neatly alingend
    ;TYPE:WALL-INNER
    G1 F2400 E3.24576
    G1 F900 X117.01 Y108.10 E3.38543
    G1 X117.01 Y116.90 E3.52337
    G1 X108.10 Y116.90 E3.66304
    G1 X108.10 Y108.10 E3.80099
    G0 F15000 X107.70 Y107.70
    ;TYPE:WALL-OUTER
    G1 F900 X117.41 Y107.70 E3.95320
    G1 X117.41 Y117.30 E4.10368
    G1 X107.70 Y117.30 E4.25589
    G1 X107.70 Y107.70 E4.40637
    G0 F15000 X108.70 Y108.70
    Just posting the above i saw that when the object is neatly aligned with the x-axis. somewhere in layer 14 it starts producing massive amounts of g-code..... The shape is stil a sqare shap, but it creates a g-code for every segment of the stl... So that is also a bit weird...
    ;TYPE:WALL-OUTER
    G1 F840 X117.74 Y107.76 E7.95765
    G1 X117.74 Y107.85 E7.95801
    G1 X117.74 Y107.86 E7.95804
    G1 X117.74 Y107.95 E7.95839
    G1 X117.74 Y107.96 E7.95842
    G1 X117.74 Y108.05 E7.95877
    G1 X117.74 Y108.06 E7.95880
    G1 X117.74 Y108.15 E7.95915
    G1 X117.74 Y108.16 E7.95919
    G1 X117.74 Y108.26 E7.95953
    G1 X117.74 Y108.27 E7.95957
    G1 X117.74 Y108.36 E7.95991
    G1 X117.74 Y108.37 E7.95995
    G1 X117.74 Y108.46 E7.96029
    G1 X117.74 Y108.47 E7.96033
    G1 X117.74 Y108.56 E7.96067
    G1 X117.74 Y108.57 E7.96071
    G1 X117.74 Y108.66 E7.96105
    G1 X117.74 Y108.67 E7.96109
    G1 X117.74 Y108.76 E7.96143
    G1 X117.74 Y108.77 E7.96147
    G1 X117.74 Y108.86 E7.96181
    G1 X117.74 Y108.87 E7.96185
    G1 X117.74 Y108.96 E7.96219
    G1 X117.74 Y108.97 E7.96223
    G1 X117.74 Y109.06 E7.96257
    G1 X117.74 Y109.07 E7.96261
    G1 X117.74 Y109.16 E7.96295
    G1 X117.74 Y109.17 E7.96299
    G1 X117.74 Y109.27 E7.96333
    G1 X117.74 Y109.28 E7.96337
    G1 X117.74 Y109.37 E7.96371
    G1 X117.74 Y109.38 E7.96375
    G1 X117.74 Y109.47 E7.96409
    G1 X117.74 Y109.48 E7.96413
    G1 X117.74 Y109.57 E7.96447
    G1 X117.74 Y109.58 E7.96451
    G1 X117.74 Y109.67 E7.96485
    G1 X117.74 Y109.68 E7.96489
    G1 X117.74 Y109.77 E7.96523
    G1 X117.74 Y109.78 E7.96527
    And when the object is placed somewhat at an angle (see picture in my previous post) the shape is maily defined by relatively long moves
    ;TYPE:WALL-OUTER
    G1 F900 X121.03 Y109.22 E30.24758
    G1 X118.55 Y118.49 E30.28370
    G1 X106.65 Y115.30 E30.33005
    G1 X109.13 Y106.03 E30.36616
    G0 F15000 X109.84 Y107.25
    ;LAYER:88
    G0 X109.20 Y107.31 Z5.53
    ;TYPE:WALL-INNER
    G1 F1080 X109.42 Y106.52 E30.36923
    G1 X110.30 Y106.76 E30.37265
    G1 X110.78 Y106.89 E30.37454
    G1 X112.24 Y107.28 E30.38022
    G1 X112.72 Y107.41 E30.38211
    G1 X115.64 Y108.19 E30.39347
    G1 X116.13 Y108.32 E30.39537
    G1 X117.59 Y108.71 E30.40105
    G1 X118.07 Y108.84 E30.40294
    G1 X119.05 Y109.10 E30.40673
    G1 X119.53 Y109.23 E30.40862
    G1 X120.57 Y109.51 E30.41268
    G1 X120.44 Y110.00 E30.41460
    G1 X120.28 Y110.59 E30.41688
    chew on this daid...... :eek: :-P
    Sorry, but with new version of Cura I've got the problems that I never had before. Surface has some visible vertical ridges. Here is an example of plastic corners printed for my friend. All printed at once in one orientation on buildplate, main speed is 80 mm/s, PLA, temp is 208C, layer is 0.25, nozzle is 0.35.
    All ridges are the same on all models so I think it's maybe software problem.
    Can anyone have a key to this problem?
    also my other print (a little statue, mostly curved surfaces) out very noisy on all surfaces. Really like in first pictures of this topic.
    http://s020.radikal.ru/i720/1404/c3/0e8ee455ddf2.jpg
    http://s020.radikal.ru/i721/1404/0d/9d683cb2538b.jpg
    http://s019.radikal.ru/i620/1404/41/7673c19b4efb.jpg
    http://s003.radikal.ru/i204/1404/b1/4648460ac41b.jpg
    Just confirmed the "when it's alingend it seems more problematic theory" in this picture you see twoo objects printed tonight. Both same settings, same cura 14.03-test2. The only thing changed is that the one on the left is printed 15 degrees tilted clockwise. Wich seems to result in a far better product......
    on the left is tilted   on the right is printed alinged with x-axis
    @Cor Kiekens: But what is with the lower part oft the objects? It looks pretty smooth. I guess that's where tha fan kicked in. If so, you could try to print without cooling and rule out a possibile cause for the wonky surface.
    the lower part is really the lower part. so the fan was at 100 percent after five layers. but the reason that the surface on the right look really bad is that Cura appears to have no problem with for instance a incredible high res cube... but if one of the sides point outwards (see my sample picture 2posts back) that is where the problems start. it also happens if the top of a nice cube was made round with a fillet.
    That makes sense, as a cube might have lots of polygons, but lines that have no angle in between get optimized out by the Cura code. So you need to make a curve for this effect to show up.
    in my first example there are no curves at all. and the effect only shows when the object is nicely alingend.???
    I finally got to test, and 14.03 Test1 for Mac gives much improved output over the final release. It's night and day. Also my retraction seems to be working better, and the Z step issues went away.
    Dear all,
    I did some tests printing the same mesh with Cura 14.01 and Cura 14.03 in Windows 8.01, 64-bit.
    It appears to be unpredictable whether the newest version Cura 14.03 gives a smooth skin surface or not. Prints sliced via Cura 14.01 give always a smooth surface.
    Adjustments in both 14.01 and 14.03 are the same; default settings ( like layer height, normal 0.1 and shell thickness, 0.8)
    Printing the spheres, comes out that the surface of the sliced models in Cura 14.03 have a rougher surface than the ones sliced in Cura 14.01
    Printing the hourglass shape, there is, funny enough, no difference.
    Till now, I am not sure if I use Cura 14.03, since I cannot predict if the surface will be rough or not. On the images it is maybe not easy to see, but here I pick them out, right away.
    images at;
    http://umforum.ultimaker.com/index.php?/gallery/album/791-curaversionstest/
    I am new at the forum, so if I missed something, please just give me the right hint?
    Did you already try the "TEST" versions?
    http://software.ultimaker.com/Cura_closed_beta/
    Dear Member,
    Thank you for your reply. As mentioned in the discussions above already, I did, -more or less-, understand that I can do some tests. Thank you for this link. I will do the tests and see if the surface in Cura 14.03 comes out more smooth, make images and I will let you know.
    Dear all,
    I downloaded Cura 14.03 Test 1.exe and Cura 14.03 Test 2.exe
    The same model.stl is used, with the same settings.
    The model, sliced in Cura 14.03 gives in this model a kind of basketry pattern
    The model, sliced in either Cura 14.01, Cura 14.03 Test 1 or Cura 14.03 Test 2 give a smooth surface.
    Since the G-codes have different content (and different kB) I tried also to load the model in Cura 13.03 with a loaded Gcode from Cura 13.01, but it made no difference.
    Conclusion; With this model, Cura 14.01, Cura 14.03 Test 1 and Cura 14.03 Test 2 give a more smooth surface.
    Question; What version of Cura is best to use? Does anybody have an advice for me?
    Images at; http://umforum.ultimaker.com/index.php?/gallery/album/795-curaversionstest-2/
    I recommmend using the TEST2. It's stable, it contains a few fixes but nothing else compared to 14.03. I'm planning to do an official update soon.
        • 56 replies
        • 29 replies
