Hi Markus,
I'll try increasing the flow although I don't like it. Fiddeling with the flow seems to be to be more of a bandaid solution because it whitewhashes all kinds of problems and does have a few side effects too (like overextrusion visible on vertical walls). Ideally I'd like to get to the bottom of the problem and not just patch the outcome. It worked before so it must be something else that either degraded over time or something that changed (filament, slicer, room temperature).
I tried different filament brands - that's not it. I'll try different Cura version next.
Top Posters In This Topic
135
46
41
31
Popular Days
Nov 20
35
Nov 18
21
Oct 2
16
Oct 12
15
Nicolinux 135 posts
gr5 46 posts
visu-al 41 posts
mevander 31 posts
Popular Days
Nov 20 2014
Nov 18 2014
Oct 2 2014
Oct 12 2015
Posted Images
mnis 11
Hi Nico
Well, regularly it is sufficient to increase the material flow, as far to side by side strands again have to each other connection. Even with this material may be required a higher printing temperature.
Did it previously work better? Or is the material from a new role?
Markus
