Retraction is actually on and I can see vertical blue lines in Cura. Here's the setting used, anyone see's something tyo correct under the retraction section?
If will try printing at lower temp and speed and disable combing to see how it improves.
Thanks!
gr5 2,192
You need to enable retraction.
If retraction is on those blue lines will have a vertical line at the start to indicate it is a retracting move instead of just a non-extruding move.
Also in addition slowing down the print speed (to reduce pressure in the nozzle) and/or lower the temperature often helps.
Also for that bottom layer if you *disable* combing it will typically force it to retract for that non-extruding move also and reduce that "scar". That may have changed in a recent version of Cura though.
