Try robert's suggestsions first.
Especially the 3rd fan!
I wish you showed a photo of the *other* side of the white teflon part. It's the other side that tends to go bad - the hot side. Also try pushing some virgin filament through the coupling to feel if there is friction. If so you might want to drill it out (3mm drill bit).
But I'm thinking your 3rd fan broke. The wiring breaks easily - especially under the black mesh covering just at the top of the print head.
IRobertI 516
Is the fan at the back of the print head running? It should turn on as soon as you turn on the printer.
It also looks like your bowden tube is not pushed down all the way into the teflon piece and held in place there. When you re-assemble, make sure that you push the bowden tube all the way into the teflon, then pull the white collet up as far as it will go while pushing the bowden tube down, finally put the red horse shoe clamp back. Now try to move the bowden tube up and down, it shouldn't move.
If that doesn't work you can try to unscrew the four long bolts a couple of turns, repeat the steps above and then tighten the screws.
