I have Ultimaker 2. The screw for adjusting the pressure on the filament is as lose as it can get, so i cant put less pressure on the filament. The flat filament you see in the picture above is when things start to go bad after the printer push the filament back and forth the feeder until it's flat and loses grip.
This is how it is when printing goes fine.
IRobertI 516
Your filament is so deformed that it has trouble going through the printer. I think you need to reduce the feeder pressure. Which printer do you have?
