Posted · KISSlicer / 14.07
Hi All!
After working with the amazing Simon & fbrc8 quite extensively, I finally have a printer that I think I can run without worries of under-extrusion so long as I stick to certain filaments (with more testing to come).
I was running KISSlicer back on 14.03, but it's been so long since I've had a truly functional printer that I haven't dealt with the new UM firmware until now. I'm trying to mimic the 14.07 Cura startup sequence, but either I'm missing something or I'm no longer able to override all actions on the printer with 14.07.
Basically I have the prefix almost down to decently match the Cura startup. I need to adjust the extrusion prime lengths, but the main issue is that the z-axis raises to ~z = 15mm before my home command even gets reached. It's almost as if there is a "G1 Z15 F9000" in the firmware that is superseding my GCode prefix. The machine will raise to the z height, THEN home all of my axes, which means the startup sequence is: bed up - home bed (bed down) - home head - bed up. Something very similar happens if I simply change Cura to output RepRap/Marlin instead of UltiGCode.
My postfix is in even worse shape; it seems to run my postfix just fine after the print (hard to tell exactly due to speed, but what I would expect), but then retracts the filament even further and re-homes the axes again. Here it's as if there is a "G1 E-5 F300" and another "G28" concatenated to my postfix.
Is there any way to get the UM2 to stick to just what is in my prefix / postfix, or is the result going back to an older firmware?
My prefix code is:
G21 ;Metric Values
G90 ;Absolute Positioning
M82 ;Extruder to Absolute
M107 ;Fans Off
G28 ;Home All Axes
G1 X5 Y8 F9000 ;Move Head to ~Origin
G1 Z15 F9000 ;Raise Bed to Head
M140 S<BED> ;Set Bed Temp
M190 S<BED> ;Wait For Bed to Reach Temp
M109 T0 S<TEMP> ;Set & Wait Head Temp
T0 ;Select Extruder 1
G92 E0 ;Zero Extrude L
G1 F200 E5 ;Extrude 5mm @ 200mm/s
G1 F50 E7 ;Extrude 2mm @ 50mm/s
G1 F9000 ;Set Axes Rate
My postfix code is:
M104 S0 ;Head Temp Off
M140 S0 ;Bed Temp Off
G91 ;Relative Position
G1 E-1 F300 ;Retract 1mm
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;Drop, Retract 5mm, Move Head
G28 ;Home All Axes
M84 ;Steppers Off
Any help is appreciated!
Thanks!
    Ultigcode is turned on in the firmware, if the file has ';FLAVOR:UltiGCode' at the start.
    If the file is Ultigcode, the startup sequence is:
    1) Home everything
    2) Move head to (5,10) with bed lowered still
    3) Heat up bed and head
    4) Raise platform to priming height (z=20)
    Then, for any extruder that is used in the print (as determined by the presence of a non-zero 'Material' value at the start of the file), prime the nozzle as follows:
    5) Advance 20mm of filament at 5 linear mm/s (this should be undoing the standard end-of-print retraction)
    6) Prime the nozzle by flushing 50 cubic mm of plastic through it, at 5 cubic mm per second
    7) If the extruder in question isn't the first one, do the standard end-of-print 20mm retraction.
    If the file is not Ultigcode, then steps 1,2 and 3 don't happen. But step 4 does still happen. This is arguably a bug, especially since the bed isn't guaranteed to know where it is until a homing has happened. Steps 5, 6 and 7 will only happen if there is a 'Material' line in the file header, which usually there won't be.
    At the end of the print (or when a print is aborted), the head and bed heaters are turned off, the head is homed, the current extruder is retracted 20mm (the standard end of print retraction) and the steppers are released. This happens for either type of gcode.
    There is no way around the initial bed raising for now, but I'll put a fix in the firmware to stop that happening when using normal gcode. At the end of the print, you should be able to just change your ending gcode to just do the mini retract and lift etc, and then let the firmware turn everything off and do the final homing.
    You can't avoid the final retraction of 20mm, but I'd be inclined to just go with it. It keeps the filament out of the hot end during the cooldown, and is going to happen automatically after a filament insertion as well. So, I'd be inclined to expect it to happen, and add the same de-retraction that the firmware does automatically, as part of your start gcode.
    Oh, so it wasn't just me then. I was playing around with KS the other day and noticed the same weird behaviour. I couldn't be arsed at the time to investigate further to see what was causing it. By being lazy I now have an answer and a free start-gcode to work from. Score! :D
    Oh, and if you aren't already, you should keep an eye on the refugee forum. Jonathan has been posting new versions pretty frequently in the 1.5 update thread lately (but keep in mind that they can be buggy):
    https://groups.google.com/forum/?fromgroups=#!forum/kisslicer-refugee-camp
    Thank you Simon, you've once again saved the day!
    I've updated my pre/post fixes (below), and aside from the initial table raise, the only thing left to figure out is why when using this code, the extruder motor skips once right before it begins its skirt path. It's not a big deal as long as your skirt is large enough to allow it to re-prime fully. I've tried many different E lengths and F speeds, but it seems to constantly do it no matter how much/little I prime or at what speed, whereas Cura does not, even at lower temps. The full-stop retraction at cycle end should be 21mm, and I'm priming 18mm quickly, then slowly priming another 10mm, so theoretically only 7mm should be getting pushed through.
    Disabling de-string stops this skipping, so I'm guessing that because of the travel length from the prime spot to the print area it's doing some form of suck and prime, which is running too fast and causes a skip. That said, I plan on dealing with the skip for now since I'd rather not disable de-string.
    G21 ;Metric Values
    M106 S0 ;Fans Off
    G28 ;Home All Axes
    G1 X5 Y10 F9000 ;Move Head to ~Origin
    G1 Z20 F9000 ;Raise Bed to Head
    G1 F100 E18 ;Forward 18mm @ 100mm/min
    G1 F50 E28 ;Extrude 10mm @ 50mm/min
    G1 Z+0.5 X-20 Y-20 F9000 ;Drop, Move Head
    I'm trying to print thin wall prints like this http://www.thingiverse.com/thing:13505. Cura isn't giving me the single pass, simple print path. I would like to try KISSlicer. Would you be able to provide any files or link to instruction so I can set up KISSlicer for my UM2? Much appreciated.
    I'm trying to print thin wall prints like this bracelet. Cura isn't giving me the single pass, simple print path. I would like to try KISSlicer. Would you be able to provide any files or link to instruction so I can set up KISSlicer for my UM2? Much appreciated.
    http://umforum.ultimaker.com/index.php?/gallery/album/1757-kisslicer-settings/
    I'm seeing the bed being homed twice before the print. Is that the issue you mention here illuminarti ?
    Apart from that it prints perfectly! :-)
    Here's a slight tweak on a Kisslicer Prefix, that actually saves time versus Cura's startup sequence.
    This preheats the extruder (to your print temp less 80C) while the bed is heating up, to save time. When the bed is 6C below the set temperature, the extruder continues heating to the set temp along with the bed heater, so the bed and the extruder are both ready at about the same time.
    G21 ;Metric Values
    M106 S0 ;Fans Off
    G28 ;Home All Axes
    M104 S<TEMP-80> ;preheat extruder
    M140 S<BED-6> ; set bed temp to Lo
    M190 S<BED-6> ;Wait For Bed to Reach Lo Temp
    M140 S<BED> ;Set bed temp to final
    M109 S<TEMP> ;Set & Wait Extruder Temp
    G1 F50 E28 ;Extrude 10mm @ 75mm/min
    Hi all!
    I'm trying to use Kisslicer with my UM2 using the prefix and postfix from @das_enginer
    G21 ;Metric Values
    M106 S0 ;Fans Off
    G28 ;Home All Axes
    M140 S ;Set Bed Temp
    M190 S ;Wait For Bed to Reach Temp
    M109 T0 S ;Set & Wait Head Temp
    G1 Z+0.5 X-20 Y-20 F9000 rop, Move Head
    but when the print starts the nozzle is to close to the heated bed, in fact it touches the bed, why??
    UM2 firmware is 15.02.1.
    Hi all!
    I've got the same problem, Did you manage to find a solution to this? I've been trying all evening but no joy yet.
    Posted (edited) · KISSlicer / 14.07
    the line "G1 Z20 F9000 ;Raise Bed to Head" raises the bed after it is already homed to 0 with the gcode G28. I think that line of code needs to be changed or deleted.
    Nope, i've switched back to Cura but @inventabuild 's reply can be useful.. worth a try ;-)
