I suppose that will work, sort of. But if the material in the extruder will burn at the extruding temperature of the material you're going to, and the material you're going to is solid at the extruding temperature of the material that's in it...
Then I guess you've got a problem anyway, since the nozzle doesn't completely empty during a material change. If we get into really high temperature and low temperature materials, we might need to change to something intermediate in between, to make the change.
Just struck me as strange to ask what the material was after starting to extrude it.
IRobertI 517
I know it's not the answer you want but, why not just change the material setting first, before unloading the old one?
