Hmm! curious device, it has a light shining on a 128x1 pixel array with the amount obscured by the filament indicating the width, but I'm not quite seeing how it works.
Does that work with translucent filaments?
Also, what happens if cross sectional area is consistent but it comes to an oval shaped section? Presumably it will increase or decrease the flow depending on its orientation.
Does the modified Marlin also track the distance from the sensor to the nozzle and, with the filament speed, calculate when in the future to vary the feed rate to compensate for the width change?
Personally I never change the filament width. I'd rather get good quality filament in the first place.
gr5 2,210
I set the filament width to 2.85mm a few years ago and never touched it. I don't think it matters as much as some think.
