innovation! did you change the nozzle size in cura, that might fix your underextrusion. it's in the advanced tab.
That is a simple temporary solution. Likely the underextrusion is caused due to the longer nozzle that was cooled by the fans. None the less a great idea!
If you insulate the long nozzle (use something like kapton tape, maybe with some ceramic cloth/tape underneath) I would actually think this could be a fine long term solution... almosth worth a try, considering the prize of original nozzles (+ shipping :eek: !)
Im actually running a 0.6 mm. nozzle atm, and with the right Cura settings it works nicely, you can finish prints alot faster too
It's a welding nozzle, for Mig/Mag type welding: http://en.wikipedia.org/wiki/Gas_metal_arc_welding
Anyway, like Tommyph1208 said, If you insulate that it might even be working (except loss of build height). Or in anycase, print a different fan shroud. Now you are cooling your nozzle
i'll try to wrap it in kapton (but i have to order some, and my 'official' nozzle will hopefully arrive before the tape)
i think that the termal loss may be is not that important, as the internal diameter is 0.6 all the way down (so, more mass, more thermal inertia)
i just noticed that the springs under the bed are a bit compressed when the nozzle hoovers over the part : my underextrusion may be due to poor bed levelling (to close to the nozzle).
That's a good solution, but don't get fooled:
The nozzle with 0.6 stamped on it is actually 0,8mm and intended to be used for MIG/MAG welding material ( as Titus already mentioned.) which is 0,6mm in diameter. So, if the nozzle is 0,6 mm, that would't fit. The 0,8 is actually 1,0mm and the 1,0 is 1,2mm. Rooie Joris printed a life size elephant with a 0,8 nozzle in 4 UMO's:-)
No problem at all, if you change the diameter to the right dimensions in Cura, I printed 1,5kg filament with it without cooling problems. (original fan housing)
If you have a M6 threadcutterplate, you can also cut the thread up to the original lenght and cut of the extend. Take a good look inside before you do this…but it saves you 10mm building height.
Another tip:
at first you put in your nozzle up to the aluminium heaterblock, then screw the brass bolt in the PEEK part. Heavy ? Take it out and cut the thread inside. Screw the brass bolt and PEEK assembly into the heaterblock Dis-assemble in reversed order.
so it is 0.8.... thanks A LOT for solving my underextrusion problem !
There are plenty of "reprap" nozzles on ebay that fit UMO just fine also.
valcrow 145
Ha that's awesome. you need to post a print made on one of those.![:p](//content.invisioncic.com/ultimake/emoticons/5a33abe3e5fc3_1f61bcopy.png)
