DidierKlein 730
This video shows how to:
Just stop at the part where you take the teflon out
says here they've improved the coupler... what's the difference?
https://ultimaker.com/en/products/spare-parts
The new coupler is infilled with 25% of glassfill to make it more resistant
If you have old couplers at home they will still do the job don't worry
That above video has you take off the 3rd fan. This is completely unnecessary - just skip that step.
Ok, thanks guys. Is the new glass filled coupler supposed to last longer? or will it eventually need changing too?
It too, will need changing eventually.
Check out post #20 of this thread for a pic of the correct gap.
http://umforum.ultimaker.com/index.php?/topic/8513-underextrusion-need-help-with-this-one/
question 1, is it time to get a replacement teflon coupler?
question 2, when was the new coupler material introduced?
Q1 it probably is worth looking at it to check for wear and deformation, my last one lasted about 600 hours, but it depends on what print material you have been using. Higher temp material seems to cause more wear
Q2 new teflon coupler was introduced last spring (April/May) last year
I would also recommend its time for lubrication of all the rods too, I use thin oil on a cloth for the rods and grease for the Z axis
If you printed 1000 hrs don't be bothered with repairing the coupler, just replace it, its a (relatively) cheap consumable ...
Yes, I would bet money your teflon coupler is toast so just replace it.
I would stick with what is displayed in that thread I linked.. And we would have to see pics of the coupler to tell you if it's salvageable. Given the amount of hours you have on it, that's highly unlikely.
braddock 1
oh... just found this thread
http://umforum.ultimaker.com/index.php?/topic/8632-atomic-cleaning-the-teflon-ring/
