Ultimaker Community of 3D Printing Experts
STEP-BY-STEP: Installation of SilentStepStick-Drivers on UMO
Posted (edited) · STEP-BY-STEP: Installation of SilentStepStick-Drivers on UMO
According to the information on http://reprap.org/wiki/RUMBA the little switches definitely represent the jumpers MS1, MS2 and MS3.
Thus you have to do exactly the same as described in the first post, the only difference is that you don't remove a jumper but simply turn the switch off.
That means:
  • First switch (that represents MS1) off (= state: "low")
  • Second off (= state: "open")
  • The third is irrelevant.
And... dont remove any pins.
    • 6 months later...
    Posted · STEP-BY-STEP: Installation of SilentStepStick-Drivers on UMO
    The UM2 has its stepper drivers directly soldered onto the mainboard. This makes it more difficult (but not impossible) to use the SilentStepSticks.
    You would basically have to remove the driver components from the board, then re-wire the TMC2100 on-the-fly. This is serious electronics tinkering, though. If you're not proficient with soldering and reading electrical schematics, then you'll have a very difficult time trying this...
    There's also the matter of wiring the UM2 board's current control circuit to the TMC2100. Not sure if the circuits are compatible (didn't compare them in detail)...
    • 1 month later...
    Hi, thanks for the great guide. I just successfully installed silent step sticks on X,Y,Z and E on my UMO. I have to say that this product is freakin awesome. My UMO is dead silent now :-)))
    This is a chinese clone of the actual SilentStepStick. No clue how it compares to the original... If they're actually using the same parts, then there shouldn't be any difference. But you never know with the Chinese...
    You can get the Original here: http://www.watterott.com/en/SilentStepStick
    /edit:
    LOL
    Looking at the pictures on aliexpress, you can see three things:
    1. it's a different layout than the SilentStepStick (but not necessarily electrically different!)
    2. There actually is a trinamic IC on the picture (good sign)
    3. The soldering quality is HORRIBLE. This is really painful to watch, being an electronics engineer... The components look like they were thrown onto the board from a distance. The amount of solder is very uneven with lots of short-circuits on some and missing solder on other pads. This is definitely POOR workmanship. My advice: Do not buy.
    Yeah, if you can get one that you have to solder yourself, that's an option to test. But I wouldn't assume it has the same performance without testing.
    The problem of the original ones is that shipping is 10 euro :p
    [...] The problem of the original ones is that shipping is 10 euro :p[...]
    I had also a tough time to accept the fee but finally ordered 4 of them a few minutes ago to make my UMO shhhhhh... :-)
    Which heatsink / heat pad have you used???
    I ordered this one:
    http://www.watterott.com/de/Stiftkuehlkoerper-quadratisch-ICK-S-10-x-10-x-125
    hope this is ok... but any hint appreciated :-)
    I ordered this one:
    I think it will be just fine... Remember to mount it on the thermal pad on the bottom of the stick rather than directly on top of the IC
    (But assuming you install the sticks correctly with bottom side up, nothing else makes sense anyways... its not like that heatsink will fit underneath the stick)
    /edit:
    LOL
    Isn't it also missing the thermal transfer pad (what do you call those), or is it just painted over? I cant tell from the pics...
    They just forgot to free the pad.
    But then they also used too large vias which wick away the solder paste from the IC's pad. Whoever designed that driver didn't care much about "details"...
    You can just put the heatsink on them regardless. Heat transfer will be worse, but should still be somewhat functional.
    [...] finally ordered 4 of them a few minutes ago to make my UMO shhhhhh... :-) [...]
    Got my SSS today but ... I´m such an idiot... I ordered 4 of them but have 2 extruders beside XYZ... so one too less... DAMN...
    Next issue: one of them came with a damaged ESD packaging... so we´ll see if I have to claim it or not...
    I finally installed my silentstepsticks and so far I'm quite happy with it (especially the noise or lack there of!). my x-axis was acting up though during a test print. I have two shifts of around 10mm, once to the right and a little later to the left. What could be the cause of this? I have just installed direct drive and GT2 belts, movement is butter smooth... maybe a faulty chip? any ideas? VREF is set to around 1.3V right now. Can it be too high?
    never mind. I misread, VREF should be a bit over 1.6V, I'll try later and come back with the results ;)
    the chips are now tuned to around 1.6V (turning the potentiometer clockwise) and my printer is now actually behaving worse. How can that be? I followed the instructions really closely, MS1, MS2 and MS3 are disconnected, the firmware updated correctly. My first test print is perfect until the moment when I lost lots of steps.
    has anyone of you got a clue how I could solve that? maybe it has happened to someone else, too? asmentioned, the mechanics of the printer are flawless (imho).
    Just leave the z-axis with a a4988 or whatever is in there now... You CAN get the machine to home the z-axis more quietly with a SilentStepStick, but that is about it... The effect while printing is negligible at most...
    regarding the ESD packaging, I would be surprised if it has caused any sort of damage to your stick (that is assuming whatever damaged the packaging didn't ALSO damage the stick...), I have never taken much care with any of the numerous stepsticks I have lying around, and never saw any faults related to that...
    1.6V for vref sounds very high... You should start at around 0.8V and move upwards slowly, testing motor strength between each adjust.... Arent your motors and sticks getting crazy hot with the 1.6V setting?
    You also mention having recently switched to GT2 pulleys... For good measure, double check that all pulley screws are tightned properly... You can check for slip by marking the grub screw position on your axis with a magic marker... after a print where your shifting layers have occured, check the marks to see if they are still aligned with the screws.
    Just leave the z-axis with a a4988 or whatever is in there now... ... The effect while printing is negligible at most...
    Thanks for onfirming my (unwritten) assumption :-)
    regarding the  ESD packaging, .... and never saw any faults related to that...
    Already got an similar answer from Watterott - I´ll use them and we will see.
    Had some troubles with more sensitive parts in future where the packing was damaged, so safety first :-)
    I will post my experience as soon I have time to upgrade...
    hey tommy
    thanks for your reply! You were right, voltage was way too high. I recently changed my electronics cooling to 2x40mm fans. It seems even a VREF of 1.25V caused the drivers to overheat. I have now tuned them back to around 0.85V and printing is flawless, at least for a 30 minute print. I'll now try a longer print and see wether I might have to improve cooling. I also just reused the heatsinks of my old drivers because the aluminium ones I ordered were too high ;).
    I'm now incredibly happy with my setup, direct drive, GT2 and the new drivers make a huge difference to my printing experience and should also decrease maintenance a bit. Less moving parts is always great!
    hey tommy
    Great you got it working :)
    When you say the heatsinks you ordered were too high, do you mean to fit under whatever cooling fan mount thingy you have sitting over your electronics?
    Im asking to make sure you put everything in correctly... Sticks should go in with "component side" facing down, and the heatsink installed on the little thermal pad on the back (now facing up).
    I myself have two Fractal Design - Silent Series 40mm. fans cooling my electronics... It's a Rumba board and the fans are centered over the stepsticks... I have never had a problem with cooling with that setup, so I think you will be fine too :)
    hi tommy
    no worries, I mounted the sinks correctly. I meant the sinks I ordered don't fit into ultimakers fan 'channel' design (the plywood that channels the cooling air over the stepper boards). I might have to redesign that part anyway though...
    I'm using this design at the moment: https://www.youmagine.com/designs/ultimaker-replacement-electronics-fan
    ... I meant the sinks I ordered don't fit into ultimakers fan 'channel' design (the plywood that channels the cooling air over the stepper boards). ....
    Which one have you ordered? Those nice alu ones from Watterott (http://www.watterott.com/de/Stiftkuehlkoerper-quadratisch-ICK-S-10-x-10-x-125) or other ones?
    Just to be aware of when starting exchanging mine...
    yes, the nice alu ones are way too big. the other ones are not in stock right now, they would probably fit, though...
    Hey yoveo!
    I added the overheating, caused by a too high voltage, to the instruction - thanks!
     Share
      • New here? Get ahead with a free onboarding course
        • 11 replies
