All Activity
- Past hour
sophisti joined the community
defitechnique joined the community
- Today
Ray001 joined the community
FetterEngel joined the community
The parts of your model aren't quite lined up: It could be getting caught when it attempts to print juuuuuust slightly further around than the main section. Also at the top, there's a small gap between the ring and the area surrounding it: It's because the ring is "rounder" (has more segments in its circle) than the model around it. The same applies to your coloured sections: Hard to see (so I added a highlight) but there's also some sections where the difference is enough that there's actually a gap between the two: There's absolutely no way I can say with any certainty that's what your problem is. But it definitely doesn't help. If it's trying to extrude slightly out of position relative to what's already there it could get a, especially if it's priming itself as it gets there. (Mod tip: you should probably edit your first post to change the title to something like "big blobs at colour change" or something like that)
Slashee_the_Cow started following Concentric Bottom Layer issue
It'd be awesome if you could attach a Cura project file (.3mf, get it ready then go to File > Save Project) of a print that has this problem so those of us with too much free time who hang around here could have a look and see if there's anything we can find that'd fix it.
mrbudman24 joined the community
I've only done bearings on UMO and possibly UM2, sorry. But for those it was 4 screws holding the bearings. Try google? The thing is, if you remove the z screw, then you can test the bearings by just sliding the bed up and down. It should be obvious. Also look if the Z screw is crooked - shaped like a curve. The z screw is triple helix so just measure with a ruler 3 threads. Or measure 9 threads and divide by 3.
S5 has constant auto bed leveling issues
gr5 replied to b3_engineering's topic in UltiMaker 3D printers
Anything over 8 is a problem. calibrating the lift switch is a complete waste of time as long as noise is at 30-60. Whether the cores are even installed or not should have nothing to do with the noise. You need to fix the noise level first. Do you have sources of EM noise nearby? Sources may include: computers motors fans air conditioners speakers things with computers in them like toasters, microwaves, cell phones, laptops, unfortunately everything these days has a computer in it. wifi access points wires that lead to any of those things - even a 30 foot wire that leads to a noise source - the wire can act as an antenna if it passes near the printer Move all those things 3 meters from your printer and see if that affects the noise. If not, move the things where they were as they weren't the problem. 30-60 is crazy high. I didn't know it could go that high! -
GregValiant started following slicing to disk
Have you tried saving to the hard drive and then coping the file from there to the SD card? You could also try formatting the SD card. They can develop corrupt memory sectors and those areas can't be written to. If you go for fomatting, remember that it will wipe out all files on the card so back up any you want to save. (If there is corruption on the SD you might not be able to get your files off it.) What printer is it? Some don't like file names over 16 characters and others can't handle large capacity memory cards.
pellertctct joined the community
bytlan joined the community
- Yesterday
MvdW joined the community
philmpenny joined the community
cancerbites15 started following slicing to disk
i do my slicing then save to disk when i put disk in printer it shows no file trying to figure out why getting frustrated
Foutjedi joined the community
I didn't have any trouble slicing it. What version of Cura are you using? The Ender 3 definition file has changed over time and some of the early definitions had "disallowed areas" that were reserved for the bed hold-down clips. Changing the build plate size in Cura would not change the disallowed areas as they were hard coded in the definition file. This is in 5.7.1.
I created two parts that were near the max X limit (setting is for Ender 3 Max Neo 300x300) and the slicer won't accept it. The original was 298mm in the X direction and 175mm in the Y direction that it wouldn't accept.so I reduced it down to 285mm and it still wouldn't accept it. I then brought it down to 253mm, no luck. However, if I scale the 253 model in Cura to 95% it will slice. The full size version slices with no problem in Creality Slicer and two others. The project I attached is the 253mm version. Exhaust vent bottom modified.3mf
jaysenodell started following macbook air m3 problems
click the object in the SLT, then scale it down by 1000. make sure uniform scaling is checked. What software was the STL created in?
mr-africa started following macbook air m3 problems
I bought a brand new macbook air with m3 chip. I tried to open different stl files, but all files were opened in wrong size: 79323.375 mm by X axis instead 79 mm I tried to decrease files and slice, but I received a warning "Unable to slice". I tried different cura versions from 5.4 to 5.7.1
tharl99 started following Concentric Bottom Layer issue
Not OP but I can hopefully help explain the issue more. I've been having the same issue through multiple versions of cura, I think the first time I messed with it was somewhere around 4.9, and I recently updated to 5.7 and its still behaving the same. I don't know why, as some prints I slice with concentric top and bottom layers behave as intended, and the layer is one continuous concentric line, while other times it seemingly decides at random to split up that layer and print it out of order. Ill attach my current profile and a model this happens on, not sure if you have the time to check or even get notified on this thread though. CE3PRO_Umikot54 - Stand Lug.gcode forumexample.curaprofile
Hi guys, Firstly, apologies for my "purge tower" description but you obviously understood what I meant, I'll just decribe it as tower from now on. Thanks for the responses. Whatever is giving it's not the bedplate. I have two Geeetech A10M's (you're right, cheap compare to a S5 but trying to find a decent dual colour printer sub £500 isn't easy, one is a standard stick-one sheet that comes with the unit, the other is a magnetic bed with a PEI plate, on only one occasion did the PEI plate move, practically ripped the plate off the magnet. I'm not joking about the tower not budging, it's rock solid. Especially on the stick on bed plate. I don't know what Geeetech use but my prints (and tower) are so well adhered I have to use a craft knife blade to get them off the bed (before your ask, no my Z offset isn't too low, even after the bed has cooled back to ambient temperature). I used to have issues with the towers knocking over but I increased the size to about 35 diameter and put a brim on them and haven't had much of a problem with that since. As for retraction I've turned it off, a peculiarity of the A10M is if your filament is retracted, the other side fills the gap and just causes jams as the two are so close to the nozzle. I know exactly what you mean about getting blobs, I had a CR-X until it died and this used to leave a length of filament on the tower about a millimeter in diameter and about 5mm long on every swap, almost looked like a sonic the hedgehog but these are definite round blobs about 6-7mm spherical diameter. I've no video but I have attached a 3mf file if it helps First attempt failed but would let me delete it so tried again so there may be two attached). GA_R3_14th Silver Dock Base.3mf Dock Base Apr24.3mf
I'm guessing a much less expensive printer than an S5, with a magnetic PEI/PC plate like my Ender-3 V3 SE. It would still be pretty damn impressive to be able to pull one of those plates off though (unless your magnets are exceptionally weak).
Okay so because I have too much time and/or refuse to not take everything as a challenge, here's a project file for a grid with (I hope) 0.2mm wide lines with 4mm between each wall, 0.1mm high (1 layer), I guessed you folks might still be using little nozzles, I can make a fatter version if you want, printed entirely as infill. I think it's changing the flow rates at intersections but it's definitely not making travel moves to avoid them: It's a UCP so you'll need Cura 5.7 to load it. UCP_grid - 5x5 0_2mm width 4mm gap.3mf
PizzaTijd started following BIG blobs on purge towers
Pictures or a video wouldn't hurt either. As slashee said, prime/purge towers are meant to look sloppy. Whenever I use it it's usually completely covered in oozed blobs of breakaway - which then don't end up on my proper print. Where it gets weird is that the blobs interfere with your print head enough to the point where it's pulling the plate with it. Prime towers are generally pretty thin in diameter and should just fall over if you apply any real sideways force on them - the amount of adhesion you would need to your build plate would be pretty impressive (ofc this is with my specific printer setup, which is an S5 with a heated glass build plate)
We were finally able to get my coworker to connect to the printers. It looks like when he created his account it signed him into his own, personal workspace. Cura could not load any printers because that workspace did not have any printers. When he signed in a few weeks later he was prompted to choose a workspace; choosing the shared workspace allowed him to immediately connect to our printers. Hope this helps others!
Walls will never overlap while printing, if they reach a line they've already done they'll travel to do another line. Infill will overlap because it's not there to look pretty. Going over (or through) an existing infill line will result in overextrusion, which likely means either a lump or the excess filament goes around and makes your corners even more round. Definitely worth a shot though.
I’m be been thinking about this. I’m assuming the corners are actually walls being printed as single extrusion. Meaning the nozzle is moving though the 90deg while extruding with no stop. I noticed that infill just prints straight lines overlapping at the intersection. I wonder if a grid infill with the right wall density would get you better 90s. Not sure the other properties would suffice, but perpendicular lines meet at perfect 90s.
Vielen Dank, werde ich ausprobieren.
Andrew_F started following Brand new just out of the box and Printcore 1 not working
Jep. Es machte für mich jedoch nur wenig Sinn da die Jerk-Änderung nach dem Ende vom Druck aufgerufen wird.
I'm sure there are some people crazier than you or me out there who are working on that exact thing. Crazy thought I just had: could you make something with as perfect a corner as possible, about equal with your layer height (as long as that's thinner than how far the nozzle) stick it on your bed precisely in position and make the filament use that as a mould for the corners? Although I guess that would only work for a layer or two, tops... maybe not the most practical idea. But hey, I'm trying! We're awesome people making awesome things. Of course we're amazing, and we get collectively more amazing as people learn how to do things like you are!
madmax21 replied to b3_engineering's topic in UltiMaker 3D printers
Hello, So the noise still persists to me also. I would like to mention the following: - Core 1 - CC 0.4 new - Core 2 - BB 0.4 new (tried with Aa 0.4 the same result) - Nozzles clean - Build plate leveled and cleaned - Weirs are correctly positioned and no damage - Lift switch calibration calibrated - Tested with front fan plugged and unplugged, no difference in noise - Fan bracket alignment correct Noise level 30-60 -
Here are the latest updates on this case. yesterday I replaced the Z-Nut and did a testprint. Sadly this did not solve the problem. Strange thing is, the lines are getting clearer and clearer after each attempt of making the Z-Movement smoother. they are now +- 4.3 mm appart from each other. The new linear Z bearings arrived also yesterday. So this will be the next step. Is there a guide on how to replace them? As it looks, the bearings are pressed into the bed so the risk on damaging something is high on my oppinion. Any guidance is appriciated.
I watched two great videos on 'pressure advance' aka 'linear advance' after watching videos on setting up Sonic Pad. And it seems the corner will have a radius of some significant amount. This would be a tip diameter of 0.2 mm or less in a perfect world (I imagine), or if I added a little more speed relative to the extrusion rate and temperature maybe the longitudinal axis can be stretched out a bit — by fifty percent? OR, perhaps I can machine a square orifice "tip" as the final step in the extrusion, attach a plate to a 0.4 mm tip — in a more perfect world, and get 90° corners down to 0.001 mm radii (at like 350°C 450 mm/sec). I'm night-dreaming. 😹 I'm printing the Sonic Pad test tower stl now. The printing is very quiet but it takes at least ten hours to complete (if nothing goes wrong). I'm waiting and I will probably have to print 1 - 4 more over the next few days if I'm going to be doing any crazy stuff. Thanks for all your help on this. I think I'm on the right track, the 3D printing community is amazing!
It would really help if you could share your Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project). At least knowing what printer you have would help 🙂 I'm not sure if you're using the term "purge tower" correctly 😕 A purge tower is what a multi-extruder printer prints in a corner usually to get the new extruder ready when before it starts printing with it. It's completely there for function and doesn't matter if it looks like crap. I'd be very surprised if your nozzle was able to grab or push the model with such force as to move the print bed (unless the magnetic force from the bed is so weak it couldn't even hold a paperclip). Skipping a step or two on the motor when it hits a blob is something which might be possible if you don't have your belt tensioned correctly. You might also want to check your setting for Travel > Retraction Extra Prime Amount: if it's retracted the filament, that makes it push a bit more than was retracted out to make sure there's enough pressure in the nozzle that it can start extruding as soon as soon as it's supposed to, but it can also result in overextrusion. I've never needed it, but it really depends on the printer (and you're more likely to need a little bit if you've got a Bowden extruder just because of how long it takes the filament to react to changes). Also if Travel > Retract at Layer Change is on, it'll be doing that every layer, and if it's overextruding a bit that effect can sort of build up. Without a project file or anything to go on it's really hard to try and make informed suggestions.
