I think others have mentioned no fans at all for this filament
The reason I have added the fans is that the filament just will not bridge for me, it just curls up and gathers as a big blob on the head. With the fans, it goes a bit solid and bridges across better.
I agree with LePaul... any fan seems to speed up the drying/not bridging type processes... but if its helping you and this particular print then why not?
The other parameter I thought of fiddling with was your 'Fill' %... why not try 100% and then work backwards and see if that will affect your support structure... does the 'support type' setting make any difference?
Fully understood regarding the writing on the top of the cap by the way.
Keep us updated though jockspice... all helps in the long run.
Top Posters In This Topic
11
18
31
18
Popular Days
Jan 7
21
Sep 1
8
Nov 26
8
Aug 25
6
LePaul 11 posts
Nicolinux 18 posts
Artiz 31 posts
Turan 18 posts
Popular Days
Jan 7 2016
Sep 1 2015
Nov 26 2019
Aug 25 2015
Popular Posts
Catlord
Your are cumulating lots of oproblems. - STOP printing at these T° with your stock printer ! As you have already done it, your bowden tube must be replaced. remove if and you
Catlord
Hi, Is your CR-10 stock or did you make some upgrade on it ? If it's stock, don't waste your time : XT-CF20 needs to be printed around 250 /260 °C and your bowden tube will start melting
Catlord
Ok lets begin then :) Stock mean you didn't make any upgrade on your printer. you didn't change the bowden tube by a quality one (like capricorn), you didn't change the hot end.
Posted Images
jockspice 6
