cloakfiend 994
Not to mention the PFTE coupler business, but again i've heard there's progress on this as well, but again i'm sure the folks aren't allowed to share any details yet. I guess you are asking when will we see these new designs that somehow clean the nozzle after the end of a print or a feeder that just feeds and just stops grinding once no material is clearly going into the head (as it clearly knows when the pressure is too high, otherwise it wouldn't grind in the first place!) or just turns the machine off at any guaranteed failure, saving burning the remaining material IN the head. I read a lot about new style nozzles that would be far less prone to blocking way back last year even before i had my UM2 but nothing since....shame. I was hoping they would be around by now, but no. Im afraid you have to just suffer a bit longer. Im more curious about the carbon 3D style printers, and the running costs of them. What materials will be available for use with them and if they can be sanded/treated, as shapeways stuff can't be sanded down, so you are stuck with that weird powdery finish unless you pay EVEN more for some cast metal hand polished business or something even more expensive.
IRobertI 516
There have been small design changes in the feeder since it was introduced. Small changes internally to how the filament is guided, addition of a metal grommet to prevent filament grinding down the housing, change to the lever design, the spring was changed and the knurled sleeve was changed slightly (the "active area" was increased).
I've personally seen a few redesigned feeders and other feeder features but I'm not at liberty to go into detail there.
As for nozzles. A ton of research has been going on there and I have seen quite a few variations (and personally tested some stuff) but, again, I'm not allowed to share details.
So yes, work is being done.
