Ultimaker 2 Dual Extruder einstellen.
Crema
Posted (edited) · Ultimaker 2 Dual Extruder einstellen.
Well 15W are 0.625 amps at 24v. I have draw more than that from that area. But ofc since its a direct connection it's important to have a dioder so nothing comes back that could dmg the board.
The only problem I see since its for fual extrusion on um2 it's that he power board 220W it's already at its max when used with 2 hotends and bed (assuming you use the default 24w heaters). So in theory it shoud be on the limit of the power supply.
    you're right neotko.
    My energy meter says I consume in heating up mode .... 221W
    1 original heater bed 2 Original cartridges + 15W water cooling
    The motors are not counting with about 40W.
    Would you advise me to a new power supply?
    IMG_2316.thumb.JPG.a16f8a68bc5d9fc3b6ddeeb31f0e43de.JPG IMG_2317.thumb.JPG.97e3d0f07b423bc017411e9cb04412c6.JPG IMG_2318.thumb.JPG.3cbe2e9109601b70930296d83fbc6d5c.JPG
    I use this one
    http://www.meanwell.com/mw_search/gs280/gs280-spec.pdf
    The only easy model to find uses a different connector. I did a cut/solder of the connector and works perfectly after 9 months of use with zero problems. It's around 90€ and it's the same company that makes the umo+/um2 power supply.
    Posted · Ultimaker 2 Dual Extruder einstellen.
    I use this one
    Thanks for the information.
    I'll then get me such a power supply.
    Not even the things which proceed here in flames :)
    Indeed! I bought that power supply to have a safe and reliable one.
    Btw the exact model with the same um2 connector it's gs280a24-r7b. But I didn't found it anywhere. The easy one to find its the gs280a24-cp4
    gs280a24-R7b I find no reasonable seller.
    I've now ordered the gs280a24-CP4.
    Thanks a lot for your help.
    Hi neotko,
    I got the new power supply.
    How did the old plug connected to the new power supply?
    greeting
    Marin
    Guten Abend,
    gestern habe ich das lang ersehnte PVA Material erhalten und gleich einen Test 3D Druck gestartet.
    Für den Anfang habe ich was einfaches gewählt, eine "Brücke"
    Mir ist klar das ich dafür kein PVA Material gebraucht hätte... :)
    Die ersten paar Versuche sind gescheitert.
    Habe ABS in der ersten Düse gehabt und in der zweiten das PVA Material.
    Meine Haupt Probleme mit dem PVA Material:
    - Es haftet nicht auf meiner Dauerdruckplatte.
    - Eine Brücke drucken ist mit dem Material unmöglich, wenn ein überhang überfahren werden muss zieht die Düse es nur mit.
    - Es verbindet sich nicht mit dem ABS es lässt sich sehr einfach entfernen.
    - Nach nur kurzer Zeit war meine Düse dicht.
    Punkt eins konnte ich mit einem Printstift beseitigen.
    Punkt vier war ganz einfach zu lösen, in einem Wasserbad... :)
    Bei den anderen Punkten muss ich noch tüfteln wie ich das Prozesssicher hin bekomme.
    Bin aber ehrlich gesagt nicht Optimistisch gestimmt das, dass was wird.
    Das Material ist einfach zu Tükisch.
    Aber echt geil, wie schnell sich das PVA im Wasserbad auflöst.
    IMG_1733.thumb.JPG.df4e774f323971068eb9580408f8dc19.JPG IMG_1737.thumb.JPG.b2308efee62103fefeee23e4d6c500bb.JPG IMG_1738.thumb.JPG.69dff60b4ae18d178ffe79dd49c9c1d6.JPG IMG_1739.thumb.JPG.7073204afae411c67dbd16e2edc7dec8.JPG
    Aber zum Glück gibt es noch das HIPS Material welches ich bestellt habe mit einem halben Liter D-Limonen konzentrat zum Auflösen.
    Leider kann man dieses nicht einfach in den Abfluss Gießen wie das PVA Material.
    Dieses muss Fachgerecht entsorgt werden!
    Melde mich wieder wenn ich Ergebnisse habe.
    Bis dann und Gruß
    Marin
    Hi neotko,
    greeting
    Marin
    I did cut the cable and resolder. Good think, the color cables are exactly the same from one board to the other.
    This is my old power supply. I save it for a rainy day :)
    @Crema: Vorsicht mit der Temperatur bei PVA... nicht zu heiss, nicht länger als ein paar Sekunden heiss stehen lassen und immer trocken ĺagern - auch während des Drucks...
    ich konnte jetzt 3 Chargen von PVA Filament testen. Leider haftet das Zeug lieber an der Düse als am Druckbett / Bauteil. :angry:
    Muss mir dazu mal gedanken machen ob eine beschichtung der Düse helfen würde.
    Ich habe auch das HIPS Material getestet und das funktioniert Prima.
    IMG_1753.thumb.JPG.a4e129c8a404b7824bc1d615c6580ad6.JPG.
    Haftet gut auf dem Druckbett und am ABS von der ersten Düse.
    Dann wurde der Fallout Boy in D-limonen Konzentrat eingelegt und über Nacht war das HIPS Filament verschwunden. :)
    Das Lösungsmittel richt stark nach Orange mit einer leicht beisenden Note.
    Und hier das Ergebnis nach dem Auflösung vom HIPS Filament.
    Für den Anfang werde ich das HIPS Material für komplexen Stützkonstruktionen benutzen.
    Meine frage an euch, kennt / hat jemand gut verarbeitbares PVA Material?
    Und was benutzen eigendlich die großen 3D Druck Hersteller als Stützkonstruktions Material? Ich konnte nur Typnamen oder Firmenbezeichnungen finden.
    Gruß
    Marin
    Wie warm hast Du denn das PVA gedruckt? Es mag definitiv nicht so warm wie PLA. Und immer trocken halten - wirklich immer. Ich habe mir eine Box gebastelt, in der das PVA liegt und dann einen Kanal bis zum Feeder. Und alles mit Trockensäckchen gefüllt.
    Die Profimaschinen arbeiten eher mit HIPS soweit ich weiss.
    Gedruckt habe ich es mit 190-210°C in ca 3° Abständen getestet.
    Habe das Material in einen Plastikbeutel mit Luftentfeuchter beuteln verpackt.
    Das Material ist extrem wasserbindend (hygroskopisch) darum diese Lagerung.
    Die Profi 3D Drucker benutzen auch ein Wax, aber welches?
    gruß
    Versuche doch mal, von 190°C noch leicht runter zu gehen... könnte ev. etwas bringen. 190°C ist ansonsten schon etwa der Richtwert.
    Hab wieder ein paar Drucke hinter mir mit dem PVA Material.
    IMG_2325.thumb.JPG.f318d5953475e82f619268b2f167b932.JPG IMG_2326.thumb.JPG.cc22e9b25d061d370f31d3a4ef8ce52b.JPG IMG_2328.thumb.JPG.df0629a824e158e3667a3c85dc19d60b.JPG
    Leider immer das gleich Bild.
    Das Material reißt ab, lässt keine ziehen zu.
    Einstellung:
    Layer 0.10mm
    Temp 1 für ABS 245°C
    Temp 2 für PVA 185°C - 210°C getestet
    Speed 20mm/s - 40mm/s getestet
    Bed Temp 113°C
    Düse 0.40mm
    Olssen Block
    Robert´s Feeder
    Material Innosolve 2.85mm neu und immer gut verpackt.
    Kann mir jemand mal seine daten sagen bei dem PVA gut Druckbar ist wie PLA oder ABS?
    Das wäre sehr nett.
    Gruß
    Marin
    Bis jetzt arbeitet meine Lösung mit der WaKü am Ultimaker 2 zuverlässig und ich musste es noch nicht zerlegen. :D:D
    Wollte ja eigendlich das System von Innen ablichten und hier Posten.
    Da dachte ich mir ich zeig euch mal den werdegang, bis zum fertigen Produkt.
    Links, seht ihr meinen ersten gedanken, es mit dem Alukühler zu integieren.
    Diese Idee hab ich nach dem Versuch schnell verworfen.
    Zu ineffektiv und aufwändig herzustellen.
    Mittig ist der erste Prototyp mit meinem SLA 3D Drucker hergestellt worden.
    Damit hab ich den Einbau versucht um feststellen zu können ob es maßlich passt.
    Hier seht ihr auch bis wo hin das Wasser Transportiert wird um eine Termische entkopplung zu Gewährleisten.
    Rechts sind meine Prototypen aus Kupfer diese haben den integrieren Düsenhub nicht und das Kupfer war nicht hart genug.
    Und noch etwas hat sich bei mir getan.
    Ich habe in eine CNC Fräsmaschine investiert um meinen zweiten Ultimaker 2 auf Dual Extruder aufzurüsten.
    Eine Fräsaufnahme habe ich mir bereits gefräßt und am Wochenende Fliegen hoffentlich Kupferspänne.
    Fragen? Oder Kritik!
    Gerne! Nur raus damit!
    Gruß
    Marin
    Beim PVA fragt sich ev. ob der Lieferant es auch immer schön brav trocken gelagert hat. Bekommst Du Dampffähnchen beim Drucken?
    Ne gar nicht, kein Knall oder Dampf als ob zuviel wasser im Filament wäre oder Lufteinschlüsse
    Habe mir PVA Semples vom anderen Herstellern bestellt.
    Evtl gehen die besser.
    Nach dem ganzen Tests mit dem PVA Material wollte ich mal was anderes Drucken.
    IMG_1768.thumb.JPG.4a5a090a934e6f479dbaa4ea6b120776.JPG IMG_1770.thumb.JPG.48bf0ace98b76d39a457692fc77c3d77.JPG IMG_1772.thumb.JPG.708c8829050bb6c980098f7eb8356bcf.JPG
    Ein kurzes Timelaps Video vom Druck.
    und
    Gruß
    @Crema: Schon nicht schlecht... :) Ziehst Du jetzt irgendwie das unbenutzte Hotend jeweils etwas zurück?
    Nebenfrage: Hast Du die Motoren auch an der WaKü?
    Ja, ich drücke das unbenutze Hotend um 0.4mm nach oben.
    Nein, die Motoren hängen noch nicht an der WaKü, mache ich aber noch.
    Damit ich einen geschlossenen Druckraum erzeugen kann.
    gruß
    Ein kleines Update von meinem Projekt.
    Ich wollte testen ob die WaKü auch mit den Standart Düsen von Ultimaker Funktioniert.
    Also wollte ich die zwei Ollson Blöcke ausbauen und durch die Standart Düsen ersetzen.
    Leichter gesagt als getan.
    Ich hatte das Problem das eine Düse sich nicht aus den Block ausschrauben lassen wollte.
    Auch wenn ich mit der Temperatur auf über 250°C gegangen bin.
    Nach einer gefühlen Ewigkeit und mehr Kraft, hat die Düse aufgegeben.
    Mitte vom Bild die gebrochene 0.40mm Düse.
    Oben ist der PTFE Coupler übel verbrannt (China Ware) der untere ist ein Original.
    Zum Glück hat der Ollson Block nur ein paar schrammen von der Zange erhalten.
    Das Wechseln ging anschließend fix und ich konnte meinen Test 3D Druck starten.
    Hier ein Timelaps Video und ein paar Bilder.
    Gedruckt wurde der Ultibod im Eis.
    Einstellungen:
    Layer: 0.15mm
    Temp 1: 245°C
    Temp 2: 210°C
    Mat 1: ABS
    Mat 2: PET
    Speed: 50mm/s
    Ein paar schwarze Flecken im PET sind vorhanden.
    Man bemerkt deutlich das ich hier die Temperatur viel zu hoch hatte.
    Die Standart Düsen Tropfen auch stärker bei einer zu hoch eingestellten Temperatur als der Ollson Block.
    Zum glück hatte ich einen Umlaufschild gedruckt :D so konnten fast alles Tröpfchen aufgefangen werden.
    Einen Fortschritt konnte ich auch mit PVA Material erzielen.
    Dazu werde ich die Tage mehr Posten.
    Bis dann!
    fragen? gerne!
    Gruß
    Marin
    Looking good again !
    Any specific reason why you wanted change the Olson blocks for UM2 blocks? whats the advantage? Do they heat/cool faster cause they are lighter?
    Hi
    By converting to the standard nozzle. Prefer compare the dripping behavior.
    And a test make whether the PVA material is better printable.
