Model isnt THAT simple, the "cup" part initially has quite an overhang to print, and the stick as you call it is quite thin...
If I had to bet I would say that Cura is slicing fine, but you have some setting problems that in combination with how these machines work, create your problems.
First off, you didn't post any temperature settings, but in general, the smaller the print (or part of a print), the lower the temperature you need... Printing that "stick" at a normal PLA temperature (~210 degrees) will melt and deform it as shown in your picture..
There are a few things you can do here:
1. Lower the temperature: When printing slow enough, you can print PLA at around 190 degrees, this will help the plastic solidify faster and reduce the constant heat radiation from the hotend while it is over the part.
2. Good cooling: make sure you have fans running at max, that they are working, directed properly etc. it really does wonders for printing small details and overhangs.
3. Print multiples at once: this is a common approach when printing small objects to help layers cool sufficiently before the next one is layed on top. Simply multiply the object in cura (say, 3 times) and enable the "print all at once" option under "Tools".
The minimum layer time setting you find in cura is there for the same purpose, but works poorly with small objects (like the stick part of your model), since it just slows down the print speed to match the layer time but the nozzle is still right over the entire (or most of the) model for the duration of the layer.
When printing multiples at once the printer will do travel moves between each model and allow the layers of each one to cool more before the next one is laid on top... As an added bonus you can pick the model that came out the best when done
3.B. Hone your retraction: Since printing multiples at once will cause travel moves, you need to have retraction enabled and somewhat honed in, in order to avoid ugly stringing on the outside of your part... The reduced print temperature greatly helps with this issue, and so will fast travel speeds, and some tests to get a good setting for retraction distance and speed (4mm. @ 40 mm./s is a good starting value... )
SandervG 1,499
For the sake of testing, have you tried printing it with like.. 60% infill or less?
Does it even print infill or are the shells thick enough to touch / create the entire stick?
