No idea what the problem is. Have not seen it before (@gr5 did ever see it?)
In the meantime you can pause and manually change material by using this:
www.youmagine.com/designs/wedgebot-for-ultimaker2
Or try the tinkergnome firmware... much more informative than the original. Google "github+tinkergnome" go to the release page and download the version for your machine. Install using the custom firmware upgrade in cura 15.xx
Joko 0
...need help ...no idea ?
