Thanks for the reply, @gr5. I appreciate your time!
Anything you can imagine measuring and finding an error you can improve...
I understand all of the caveats and the fiddling that can be done. This isn't much comfort to me, as I'll be the sole source of support for the station WRT 3D print jobs. I'm hoping to not have to tweak & reprint every job that comes through the door (and won't have time for that anyway).
My question was more practical. Has UM (or anyone) actually tested the limits of the performance of these printers in a robust way? Do all the tuning and tweaking you want (thought that's not quite fair to the consumer) - what can the printer really do? I think this should be done using the default nozzles and materials.
So this kind of measurement is difficult.
Formlabs did it and was completely transparent about the results. I really respect that transparency (especially since I wasn't impressed with their results).
It's best to just go to 3dhubs and find someone near you with a UM2 and ask them to print your part and just look at the results versus someone near you with a form2.
I mean, I don't mean to be such a Type-A scientist, but isn't this test something that Ultimaker should have done as part of R&D? IMHO, saying, "There are so many variables we can't really test for XY print feature resolution" is a cop out and doesn't lend much confidence in the machine.
Don't get me wrong - the UM3 is my leading contender right now. 8)It looks like an amazing FDM printer. I am just really surprised that this kind of characterization hasn't been done, and I think the results would be very helpful in assessing the true performance of the unit. ¯\_(ツ)_/¯
This is very interesting. The thing is that atm UM, afaik, focused on the important part to release a new machine, having it 'work' on a number of common and more complex scenarios (where some of us got in doing beta before the release) and the main goal was to help UM to help find possible issues so everything could be as smooth as possible. Said this, I really thing that once all the initial release is done, that kind of information like material expansion, per material / color / type, should be possible to compute and get on a nice chart so future releases of Cura can manage that data to try to adjust as much as possible to the goal of printing with just one button (I think this is the golden goose of 3d printing that will take time, even years, to be possible for FDM). R&D guys are amazing (saying this after having the chance to meet some of them) they do spend a lot of time doing really interesting tests, but mind this, atm the focus (or what I thing the goal was) is to be able to print as easy and as good as possible. After this initial part I think that, like you point, this kind of data is really important in order to get more accuracy on the prints. And since UM3 has the filament spool sensor (for UM brands atm) it should be possible to add the kind of information you want, but also mind this, on a SLA printer you can have much more control over a certain number of parameters, you don't have a moving head but only a Z motor and a light source to 'print'. So ofc, there's much less parameters to control, and also there's much less materials. Ofc, also SLA has some very interesting materials, but also it has, for what @IRobertI told on a chat, much more stuff after the print is done, for example (and about this I only remember parts from what @IRobertI told, you need to do Post Curing after printing, you need a cabinet to it faster (and I assume is a requirement to get more precision?) and most of the chemicals can have nasty odors and require gloves, mask, etc. So SLA could look cheaper, but also the materials are more expensive, and with a FDM you get more variables to control but cheaper and less (or close to zero) odors or particles in the air.
I think both technologies will evolve, and since SLC has less materials and a more controller environment the kind of data you want is easier to obtain, but with FDM you get more flexibility and cheaper materials, less ambient problems for most materials in exchange for more variables.
I must say that I have never used a SLC. And I also agree that we need more data to control more of the variables at hand and get more precision. But I bet that's somewhere on the UM to-do along the way.
gr5 1,870
So for example the printer tends to be pretty consistent if you use all the same settings in cura. If a key section of your part is 10 microns too big just reduce the part size by 10 microns in cad and it will probably come out perfect every time after that.
But change filament type or temperature or speed or infill speed or infill pattern and now you have to start over with the measurements.
fdm printers have a round nozzle hole - default for um2 and um3 is .4mm so you are going to get a radius of curvature on corners of 0.2mm. HOWEVER you can always put in a smaller nozzle such as a .25mm nozzle. But now your prints will be 4X slower.
The great advantage of fdm over sla printers is mostly materials. You have more materials to choose from with fdm and they tend to be less brittle. Also price. FDM materials are much cheaper than resin.
So this kind of measurement is difficult. It's best to just go to 3dhubs and find someone near you with a UM2 and ask them to print your part and just look at the results versus someone near you with a form2.
I'm not sure but my gut says the UM2 will probably print a little better than the UM3. Partly because people who have a UM3 couldn't have had it very long and probably aren't experts with it yet. Partly because the head is lighter.
thalassa 9
Don't get me wrong - the UM3 is my leading contender right now. 8) It looks like an amazing FDM printer. I am just really surprised that this kind of characterization hasn't been done, and I think the results would be very helpful in assessing the true performance of the unit. ¯\_(ツ)_/¯
meduza 191
I can tell you without printing what would happen if you tried to print the test model that Formlabs used on a Ultimaker 3. The features would not show up at all.
Why? All the features they test are smaller than the 0.4mm nozzle, so the slicer (Cura) will just ignore them.
Edited by GuestLink to post
