Ultimaker Community of 3D Printing Experts
  • Sign Up
bagel-orb
Cura 2.4 beta is here!
Posted · Cura 2.4 beta is here!
One question about this version, have not yet tested it, but there seemed to be a bug in the 2.3 version with one at a time printing, where the retraction between prints was to big causing massive underextrusion at the start of the second print.
Is this issue corrected? (Just had one user report this issue in the french section). And had one customer with it too...
Share this post
Can you give more details? What happens? Which platform?
Share this post
As you guys might have noticed, Lulzbot is also working on Cura 2.x these days. They have already made a pull request that was a bit too late for 2.4 that adds a G-Code reader to Cura. They've also mentioned that they are going to work on better USB controls.
FieldOfView also made some mockups for how the jogging / remote control should look in Cura.
Share this post
Posted (edited) · Cura 2.4 beta is here!
Looks like there's still an issue, at least in Windows (7 in my case) not loading
I tried to be good.  Un-installed previous version (2.3.1) and installed 2.4 Beta.
Not launching.  I recall previously something had to be renamed somewhere in appdata last time, but can't seem to locate those details.  Help!
(At the rate you guys change versions, it would be really convenient if you nailed down this bug!)
(p.s. Keep getting Error 500's on your website today)
Share this post
The link to the answer is just one post above :)
Here's what it links to:
Won't load for me at all. The splash screen comes up and then it just closes. :(
Same was happening for me. I uninstalled 2.3 and then moved out the directory under Users/name/appdata/local/cura (or whatever, I'm going from memory). Then it came up fine.
I'm still not seeing cubic subdivision infill show up though in the layer view. This is a bummer, because this feature is the only reason I uninstalled 2.3 and installed 2.4 beta to begin with.
Share this post
But WHAT was moved? The comment "whatever" doesn't help me much :)
Share this post
The directory Cura under appdata folder (just type appdata in your file explorer it should point to your directory.
Move that folder to a backup anywhere (so cut and paste)
Share this post
Okay, I follow you now.
For others...
Using File Explorer, click over to
C:\Users\{Your profile name]\AppData\Local\
RIght click on the cura folder, select Rename, rename it 'cura.bak' (or whatever) and hit enter
Fire up Cura 2.4 Beta It'll take a few moments and then open
And...my first grievance! "Scale Large Models" on ON by default! FIX this! :D
Share this post
I'm sorry, the Beta 2 has been published few days ago and I don't see thread update
Share this post
The hollow prime tower has been removed in Cura 2.4 beta 2.
no it's not ......
Share this post
no it's not ......
You are right, I have made a mistake.
Share this post
Nor do I. I've been looking around the forum and not seeing a new thread on it?
Share this post
>>snip
Who ever stops after just slicing?
Well me for one. I have always used Cura to slice and Repetier Host to control the printer - lots of advantages including usb connection. Cura is on one laptop and drops the STL onto a network drive and the printer laptop, attached via usb, pulls the stl from the network drive and prints it.
Of course if one is used to using Cura to print I can see the issue is a bit of a b*mmer. For me Cura morphing to just a slicer is OK.
Share this post
Can I just add my request to the list to sort out the implementation process so that different versions of Cura can co-exist on the same laptop. I would love to get my teeth into 2.4 beta but I am too busy at the moment to risk screwing the machine and not being able to get 2.3.1 back quickly and correctly. Right now a loss of a days production would be disastrous and will remain so for some considerable time.
I guess I could spend 500eu on another laptop but that sort of defeats the object of Cura being free. Mind you I wold be happy to pay for Cura if this sort of thing was working.
Share this post
