Its hard to say but in my experience (more than three years with UM2) the Teflon coupler I have replaced several times but since I installed an 'I2K' spacer from 3D-Solex I have not had to replace the Teflon piece again, now more than 600hrs since last change.
I suppose you may need to replace the Teflon Bowden tube occasionally, in my case I have replaced once.
Also the print nozzles can wear out from printing abrasive materiel, like metals filaments
Labern 763
Any moving part will wear over time but with regular maintenance like cleaning, Oiling, Greasing etc. you will prolong their use.
The Main consumable parts are nozzles and TFM coupler.
You can get replacement TFM or TFT couplers from different manufacturers and these can now last 1000s of print hours compared to the old UM2 setup which could only last 1 spool.
The belts do wear and stretch over time. Mine lasted 2 years and now require replacement but this depends on how often you print. You can print new spacers to help align these to help stop any side wear on these.
There are lots of manuals and guides with advice on how to do the maintenance so dont be put off by it.
