GregValiant 1,318
If you know the current draw/power usage you should be able to find an inverter that will work. That would avoid having to do anything but plug it in. A quick search turned up a 1250 watt inverter for $70 US. My Ender 3 Pro is only 270 watts.
medicalmodeller 5
I am planning to take my U2Go onto my boat. As the boat has both 12v and 24v DC available I wondered to avoid using the power supply unit that requires AC. Has anyone powered straight from DC supply?
THanks
MedicalModeller
