Dim3nsioneer 559
Do you need to worry about couplers degrading with the Ultimaker 3 ?
The disassembly (
) of the printcore did show a piece of teflon :/
No it's protected by the double heat break. Afaik it never got warmer than 100°C in the stress tests Ultimaker performed before the UM3 launch.
1
IRobertI 521
It's not the material itself, it's the temperature. Any material you print at a higher temperature will make the PTFE coupler degrade faster. How quickly is a bit unpredictable as it depends on exactly how hot you're printing, how fast your fan is cooling the PTFE and even how many retractions you're doing. The PTFE will die eventually, regardless of which material you print (including PLA), it's considered a consumable.
The UM2+ uses a different kind of material, called TFM and it also uses a spacer instead of a spring. This combination lasts quite a bit longer than the PTFE+spring combo. So I would suggest you get a TFM+spacer when you need a replacement. It's important to get the spacer instead of the spring.
You can find a reseller here:
https://ultimaker.com/en/resellers?c=US
Here are instructions on how to replace it:
http://support.3dverkstan.se/article/56-replacing-the-ptfe-coupler
cjs 34
The disassembly (
