I am convinced if you have the white UM Mainboard you should have th A4988 drivers.
If you don’t I can’t tell.
Mine is an UMO from early 2012, with a green motherboard ver 1.5.7
It seems Ultimaker used A4988, schematic here
https://github.com/Ultimaker/UltimakerOriginal/blob/master/1098_Stepper_Driver/A4988.pdf
Thanks for digging Conny. I'll take that as a confirmation for A4988 chips. I looked pretty hard and could not find it. I'm still interested to know if the SSSdrivers have the end of step issue or not. At this point, I have no evidence to suggest yea or nea. Lack of it being mentioned may prevail.
Quieter is always good. Not so significant for me - I print in the garage.
Matt
Edited by GuestQuieter is always better. I suspect they don't need the tl-smoother but it would be great if you could do a before and after print with the SSS chips and let us know.
If you live in USA and do decide to get tl-smoothers consider shopping from my store at thegr5store.com.
If you have what I'm looking for gr5, I will gladly buy from your store. You do a lot for this community, and deserve more payback. I've looked before, but couldn't find a reference to the store. You should plug it more often, maybe in your profile if its possible.
I do appreciate your help here as always.
For my issue currently, I'm gong to read a bit more about the SSS driver chips and how they handle current decay - and/or - go ahead with the ROSC to ground jumper.
How about doing both to learn - ground the rosc today and order the other drivers in parallel ;-)
I completed the ROSC ground jumper. Actually the surface mount resistors unsoldered accidentally, so I bridged the resistor location with solder (or at least I think I did - it's hard to see) The resistors are lost, and can't go back on. I'm fairly good at soldering, but this is very small work and difficult for 47yo eyes. I did this to the X and Y chips only, and then reprinted Torgeir's test piece. The longer straight side of the piece (side A) was basically parallel to the Y axis. This side has greatly improved in regard to the vertical lines discussed in the Zebra Stripe Thread. The most curved side (side B) however was basically diagonal across the bed, and has what I think are pressure ripples (can't think of the common term for these) that emanate from the Z seam. The first print had this, but to a much lesser extent. Of course, I used the same gcode, same filament, same temps etc on both pieces. This is natural colored ABS, layer height .15mm.
Pre jumper part is on left labeled "1". Post jumper is on right "2"
Side A was printed parallel to Y axis: The lines marked in the first piece are definitely gone on the second print, but the ripples are new.
Side B was diagonal toward rear left: Major ripples
Side C was parallel to X across front of printer: Way better on the first pass.
According to info found in the Zebra Stripe Thread , R4 is to be jumped to ground for the desired effect:
Not sure what to think. I think I'll try again tomorrow. If I got the chips mixed up, would it affect the current settings? Maybe one of my solder bridges is not really connected?
Time for bed and the printer is out in the garage. I wonder if I bumped the X motor loose when I tipped the printer over for access?
Edited by GuestYes, double check everything tomorrow.
For that kind of work I can recommend this kind of magnifying glasses:
http://www.eschenbach-sehhilfen.com/de-DE/278/produktuebersicht/detail/82/laboCOMFORT
with 2x or 2.5x.
No issues with small SMD anymore.
Edited by GuestAfter sleeping on it, I will first check my belt tensions. If loose, will correct and reprint. If not, then print another test piece with the x & y chips swapped to see if the problem changes...
Is there a reputable source for the SSSDrivers pre assembled for UM's?
I bought the SSS for my 2012 edition UMO - the TMC2100 - directly at Watterott.
http://www.watterott.com/index.php?page=product&info=4107
It was a straight forward change with only one hurdle at the second extruder.
Just make sure you buy the right heat sinks :-)#
I can fully recommend the SSS as my UMO got that quiet and also the zebras have been nearly gone (but I never discovered them as THAT annoying...).
If it also has effect on the end-of-step-uneveness, I have no idea, but keep us updated...
Edited by GuestI guess I am guilty of Re classifying the Zebra stripe to something more name precise based on the findings in the Zebra Stripe thread, so same thing as I see it, but more specific name? Sorry to make more confusion.
The symptoms (lines) in my first print mimic the 'zebra stripes'. I think they were corrected in one axe of my second print with the ROSC ground jumper added, but something else or questionable continuity of my jumper in the other axe caused the bigger waviness. Watterott is across the pond for me, but that could be ok
@mastory please update your profile to indicate what country you live in. Even if you tell me here I'll forget again later.
Definitely get some cheap reading glasses. I got my first pair at CVS. Get the strongest they offer. Seriously. The strongest. You want around "10X" (meaningless number) which is about 5 diopters. This allows you to focus much closer so you can look at a part from just a few inches/cm away and see great detail.
Also I'm not sure what you are printing but this is the best zebra-stripe-test https://www.youmagine.com/designs/curve-test-print
Gr5, that's the same part that I'm printing
tommyph1208 55
I run SSSDrivers on my UMO, but am not aware of the issue (maybe that means I don't have it? Or as you also mentioned it, maybe I just accepted flaws like that, writing it off as the bed shifting slightly, or similar...
Regardless I think the SSSDriver swap is a no-brainer for any UMO owner, as it just overall makes for a much nicer (primarily quieter) printer.
You mention it being a stretch for your capabilities, but speaking from experience it is really not that difficult... There was a lot of confusion at first as to how to properly install them, but in the end they are extremely close to being a drop in replacement for the stock drivers (which I do believe are A4988 ).
The current adjustments you are talking about are done on the drivers themselves with a little screwdriver... There are vias for measuring ref voltage with a multimeter on the driver as well, but you can also just go by the trial and error approach and adjust until they are running right.
As for reversing axis you can get around the firmware update issue (if that frightens you) by simply turning the stepper motor cables 180 degrees.
If you prefer one of your other solutions that depend on A4988 drivers, but are unsure the ones in your machine are A4988 or A4983, why not just buy a new set of A4988 and drop them in? They cost next to nothing... You will have to adjust current on those as well.
Edited by GuestLink to post
