13 minutes ago, fbrc8-erin said:Does it only error out when you try to start a print? Or will manually heating the nozzle also cause an error?
It wont even start up when i get the error message. It hangs and indicates the error on the display, mentioned above. If i swap the sensors however the system starts up and displays the ordinary menus.
fbrc8-erin 296
