18 minutes ago, SandervG said:Do you have a photo of what you considered to be Z wobble?
Sadly I have no picture. I fear to activate the auto leveling again. My bed is leveled perfect now and you should not change a running system....
Well I want to open a new topic to fine tune my settings. Therefore I will set everything to default and start from scratch. I will activate the auto leveling again and make pictures of course.
If everyone here is using the auto leveling and nobody has a problem then something is wrong on my side...
QuoteYou can define in what frequency you what active leveling to happen, which can also be never. I.e., turned off.
But not during a print. You have to decide if you want to change your active leveling frequency before your print starts.
Can you elaborate what you mean that you have to make a manual leveling to overwrite the saved alignment. What do you mean by overwrite it?
My theory is the Auto Leveling consists of two functions.
1st the automatic Measuring. You can activate this in the menu and you can set the frequency (before every print).
2nd the active Leveling. You can not activate/deactivate this. Once the automatic Measuring detects a slight dealignement of the bed the active Leveling will correct the bed hight while printing so the printed object is always aligned to the bed.
When you activate the automatic Measuring the position/alignement of the bed gets saved and the active Leveling will always adjust the bed hight while printing.
Even when you deactivate the automatic Measuring before the print, the active Leveling is still active because it thinks that the bed is oblique.
You first have to do a manual Measuring (Leveling) to overwrite the saved position of the bed. Now it thinks that you aligned the bed correct and deactivates the active Leveling while printing.
... that's my theory.
Edited by Dragon2781
SandervG 1,522
That is how it measures any offset in your bed leveling.
That is correct. It does this during the first 10 layers of a print.
