I've had similar issues when trying to print a threaded coupler with PVA support. Sadly I can't offer an explanation as to why this happens, but to my eye with my model, and perhaps yours, it seems as though there is a bit of interplay between the support model and the primary one.
Not the same as trying to print a two color model with two AA cores, but something along the spectrum from totally integrated to totally separate. In my case, the layers in the threads seemed to come out 'un merged' where it looked like interleaving between PVA support and PLA model layering, when I expected just PLA.
I know your model is pretty complex and clearly benefits from support. Have you tried printing a partial version of it without PVA support to see if the surface texture is better (that is, in the areas that don't sag without support)?
Also, and pardon the dumb question, but is there any possibility that age or moisture level of the PLA or PVA are a factor? In my case, I put both the PLA the PVA in a dryer for a day or so and tried again, though not perfect it did make a difference.
John
Edited by JohnInOttawa
phi90 1
I don't seem to be able to edit the original post anymore? Anyway,here it is!
