first feedback;
Install, ok
sensor test, ok
object based probing, not ok (Cura 4 beta 2)
Sliced a tiny part, but it still probed the height of both nozzles, and it probed about the hole green area, not only the relevant area around the object.
And even for the first print after firmware update the ,material was retracted so much that also the prime blob was not enough, so if you try this firmware just manually push the filament a bit....
ahoeben 1,148
More importantly, quoting from the blog post: "The internal lights of the Ultimaker S5 can now be completely turned off."
Hurray!
RudydG 56
Olala!!
Seems to be all the things i wanted. I am in the middle of a long print now, but once it is done, i will certainly try it out.
