Guest maht
Posted · Ultimaker Cura 4.1 stable
Thanks for all your feedback during the beta phase. We've just launched the stable release on Ultimaker.com.
Some notable features in this release:
-          Add separate brims to prime towers
-          Drag and reposition panels everywhere in the interface
-          A new gyroid support pattern contributed by @smartavionics
Check out the blog hereDownload now and give us your feedback in this thread!
Thanks all!
    Same problem here, Cura 4.1 on a brand new install of Windows 10 Home, Cura is running as a background process only, cannot see any GUI. Single monitor, 4GB Ram N4100.
    Running in compatibility mode for WIndows 8 seems to allow the program to launch successfully.
    I was hoping the infill near holes/edges was fixed?  I have several posts about infill overlap not working correctly (using Ultiamker's Cura profile for my Ultimaker 2+, Ultimaker filament...)
    No photo description available.
    17 hours ago, BigLebowski said:
    Installed 4.1 but it shows the same problem as 4.0 on my laptop. The process cura.exe gets started but the GUI doesn´t come up. 😣
    Can you post / send your logs please? You can find it in C:\Users\[users]\AppData\Roaming\cura\
    Can you also try again by killing the task and try restarting it?
    Also for you @GriffinDodd
    Just noticed that it works if you use "Start as Administrator" to launch Cura
    update from 4.0.0 stable to 4.1.0 deleted all my setup, printer and material.
    i did NOT remove my setting during uninstall of 4.0
    thanks.
    Backup from 4.0.0 not working in 4.1.0
    Posted (edited) · Ultimaker Cura 4.1 stable
    Could everyone please report any / all issues on github (https://github.com/Ultimaker/Cura/issues)? When doing so, please fill in the entire issue template and provide logs
    Edited by nallath
     I think it's a good first step: But why stop midways and stay inside the interface instead "Drag and reposition panels everywhere in your desktop? With multiscreen environments becoming more and more ubiquitious, why restrict panels to the interface, where they will always hide some portion of it?
    Because it's super annoying to get that to work on all platforms.
    • Like 3
    Ok, sadly accepted...
