1 hour ago, davidconeff said:Is there a way to do this via plug-in and not having to get too familiar with the Cura codebase itself?
I'm afraid not. You would have to delve into the C++ code in the backend to be able to add/change the skin patterns.
1
davidconeff 0
Cura is open source, but I'm not seeing an easy way to drop in and modify the available top/bottom patterns. I'd really like to be able to tell it to do an interlaced pattern that initially fills a top layer with separated strands, then fills in the gaps between the strands. This would solve the general cooling+curling problem that I observe with the "lines" pattern on the leading edge of some prints as it fills in a continuous layer.
