Oh yes indeed, it's a bit much!
We must now see how you can troubleshoot.
I have not received. Pressure mounts for me!
Alex.
Alex.
The problem is fixed now after I removed the bottom cover that made that short. now the bed moves up & down & no more gridding sound.
I also leveled the bed & passed step 4 but I still need these aluminum glass holders as paper clips are too thick & would hit the extruder.
Lets just hope they do send them.
P.S: Did they print that sample before or after fixing the cover ?
Another small issue, while the printer heats for the 1st time to load filament, it keeps heating & the extruder starts smooking a lot, so I look & it seems that the temp sensor is falling out of place from the back side.
nothing that cant be fixed but still, this is getting annoying.
Ok, this is crazy, and it should not have arrived in a state like that. It's not slightly damaged, but heavy damaged.
I'm forwarding this to both support and logistics. I'm sure you get a proper response ASAP.
Hi Naz72,
Thank you for your post.
This will be immediately sent to our production department as feedback and I will make sure no printer leaves our building in this condition. It is unacceptable.
We have an extra quality check before the Ultimaker² is being shipped. I consider this a human error given the fact it slipped through. Perhaps it should be tighter so this will be ruled out in the future.
Our apologies for this inconvenience. I hope you understand this is not how we intend to ship out Ultimaker's.
I will contact you in a direct message so we can find an appropriate solution. If you want we can sent you a new Ultimaker².
Thank you Sander for offering to send a new printer.
Really happy I went with Ultimaker, this goes to show the kind of support you get when you buy an Ultimaker.
I wished the machine would have proven that in the first place!
I am glad you are pleased with our offer. Lets focus on solving this asap.
I had the same problems with the clips. 1 bend the other one broken. Allready opened a ticket last week.
Hi Jamboy,
Thank you for your reply.
Could you sent me the ticket ID number in a personal message so I can look it up?
Thank you for your time,
I think I actually got a lemon, my bad luck, I know for a fact not all printers are coming out like that but never the less I wish someone had checked & made a better job at packing especially for us international users.
some more photos
messing around with the printer a little & it seems both fans on the extruder side don't work at all. Again I have to dig into the printer & electronics to find out why & provide updates here.
Hi Naz,
Inside the black wrapper just above the printhead are 3 connection points. You could check if those are all still properly attached. You could also check if the connection at the electronics are still connected.
On another note, I have a hard time identifying the part you took a photo of.
Can you make a picture with a wider angle?
Hi Naz,
Sure I can, which photo are we talking about ?! The frame in the last pictures ? These are the cuts for filament holder.
now i see!
I had a hard time putting things in perspective. Thanks.
Well, the material has already suffered a lot!
In transportation?
It's been two posts that talk about connectic fans on the UM2. This is a sensitive area. As the tray.
For transport still, perhaps as offending the packaging is that the manipulation was done correctly by the carrier? How did it worked and secured for the trip?
It will be the team to listen, because it's a bit much.
In any case, I hope a quick, correct and then with full resolution beautiful results. But it must be frustrating! Good luck, the solution is at the end;)
Cordially.
Alex.
Its not really DHL as the machine didn't show any signs of bad handling, its defiantly the bad packing from the inside & this has to be unfortunately directed at Ultimaker, the Glass bed was completely loose & I'm glad it wasn't broken.
Here is some more small issues that are really starting to get to me. one of the fan Cables is loose "Again". hope I don't face any other issue one this is fixed as I really waited long for this printer was looking forward to printing my new Transmitter design for my DJI S800 Evo.
Ok, sorry for DHL.
It is true that the scope of wire shorted and now the connector ... Poor crimping!
If you are gifted with a good material that is easily repairable. But hey, it will be the response by Ultimaker against for more!
Good luck;)
Alex
Some more updates, fans don't work after wire fix, have to check the connection to the PCB board.
Another issue now is with Cura, retracting every second, too much retraction that it eventually stripped the filament & stopped extruding, have to save to stl 7 print directly from the printer to see if that is a Cura issue since I don't have retraction enabled.
:sad: :sad: :roll: :roll:
Not happy, really, I placed an order for Makerbot 2, since I needed two machine to work in parallel & that was my 1st choice but went with the Ultimaker 2. I have already the older Ultimaker & now this, so its time to compare in real world tests.
will provide updates as I go along, since I'm a little ticked off right now to work on the printer, hopefully another day 7 another better luck :-P
Hello, I'm not talking French anglais.J uses it for googole traduire.J 'have also had my Ultimaker 2 with the glass tray completely travers.Je think may be transportation? Must make an effort for the emballage.Par against, I have a little problem on the underside of the machine.Elle was not very stable when I put it on my bureau.Je explains about the four corners only 3 are in contact on the desktop . there a difference from March to May millimeter on the corner for a photo before gauche.Voiçi comprendre.Mon office is well niveau.Je will contact ultimaker.J 'have also had a bug in court printing error-stopped , redémarage forces? on me after an electronic problem. cura In for Ultimaker robot, it tells me the temp 35 minuttes impressions, while the OLED controller indicates 1 hour to print its not match.
For shipments, efforts should be made to the board. Really!
Wow Naz that is some machine they have shipped you.. Have you had a reply to any support tickets you put in ?
Mine arrived with the glass plate not in place, and my third fan is not working, I have put a support ticket in regarding the 3rd fan but no response....
I have checked the plugs and wires by the print head and all seem ok, being new to 3d printers i was looking for ultimaker to support me further in trouble shooting the issue
Cor3ys,
Sander did offer to replace it but unfortunately that is another problem since I have to hand this one & wait a couple of days until I get the new one & I really don't have the time to wait, I have been waiting for a month since I ordered only to find that the printer ships on the 24th after I laced the order on the 1st, but I decided to stick with them.
I did open a ticket but I never got a reply yet, only here on the forum.
There is a new setting in Cura 13.10 to help with this:
expert config: retraction: "minimal extrusion before retracting (mm)" This helps stop exactly what you are talking about - retracting over and over on the same spot of filament. This has never been a problem for me on the UM1 so I was surprised to see this new option. Maybe the UM2 grips harder on the filament than the UM1.
Top Posters In This Topic
33
12
7
6
Popular Days
Oct 29
37
Oct 28
25
Oct 30
15
Dec 18
6
naz72 33 posts
SandervG 12 posts
illuminarti 7 posts
geeks 6 posts
Popular Days
Oct 29 2013
Oct 28 2013
Oct 30 2013
Dec 18 2013
naz72 0
Here are some pictures, also I decided to open the bottom cover, and guess what, it seems the cover pressed against the stepper motor wires & short them, see for your self. Very unhappy after all this headache of waiting for this printer.
Quality control !!
quick job in assembly to rush them out the door ?? round screw head ? not flat ?
short circuit (The movie)![:p](//content.invisioncic.com/ultimake/emoticons/5a33abe3e5fc3_1f61bcopy.png)
