DivingDuck 105
Looking at the dates of the file, they are from beginning 2020. You can think about updating your plugin as a first good idea.
https://github.com/smartavionics/RawMouse/releases
Don't forget to delete the old files before updating as file structure had changed quite some time ago.
17
11
10
5
Popular Days
Jan 23
8
May 4
7
Jan 16
6
Jan 26
5
DivingDuck 17 posts
burtoogle 11 posts
Smithy 10 posts
MarcusWolschon 5 posts
Popular Days
Jan 23 2020
May 4 2020
Jan 16 2020
Jan 26 2021
Popular Posts
burtoogle
I have created a plugin that lets Cura access HID mouse devices such as the 3Dconnexion Spacemouse. It's called RawMouse because the plugin interfaces directly to the raw device without the aid/hinder
mbourque
I just started to use this and found the 3dmouse move opposite than expected. On a hunch I edited the config.json file and reversed the scale so that anything negative was positive and visa versa. Now
burtoogle
Hi @DivingDuck, thanks for the feedback. I can understand your wishes. As you know, at the moment, RawMouse simply emulates the normal 2D mouse so as that can't roll then neither
Posted Images
KyrTryf 0
* EDIT: Nevermind! I had to install the latest version from here.
GitHub - smartavionics/RawMouse: Cura Plugin that lets you use a HID mouse to pan/rotate/zoom the view
Hello,
I had extracted to the path you said but i get an error. Any clue what goes wrong?
Thanks a lot in advance.
i get this error:
Edited by KyrTryfLink to post
