When I first got my UM2 printer I saw the gluestick that came with it, and assumed I was supposed to use it every time. I lathered it on. You may remember that my first few posts was about the difficulty of getting the finished print off the glass. Everything else about the print at that time was default PLA settings, so the bed was heated as well.
Then one day I started a print after forgetting to apply the gluestick. I was surprised that the print went perfectly, and popped off the glass much more easily once it cooled down. Ah! I thought, the gluestick must be for ABS only.
Since then I didn't use glue and the part has become easier and easier to remove... until yesterday, a tall PLA print separated from the glass while it was still printing. I applied glue and it went fine... and was noticeably better stuck to the glass at the end.
So, now I'm thinking that PLA does benefit from a thin coating of glue, but you only need to treat the glass every now and then, not every time. I.e. when you notice that the print comes away a tad too easily.
I've skimmed this discussion. I was surprised about the bit about temps over 60C being bad, but it makes sense. I'm not sure why wood glue is being suggested. Surely you must be talking about white PVA glue, which is basically the same stuff as the gluestick. I can't immediately see why an optically perfect film is necessary, though it'll certainly be elegant. Obviously you don't want lumps of the stuff, but IMHO the heated bed will smooth it out anyway, within reason.
Top Posters In This Topic
16
8
6
4
Popular Days
Nov 19
12
Mar 24
9
Feb 21
6
Jan 4
4
gr5 16 posts
drayson 8 posts
burki 6 posts
jameshs 4 posts
Popular Days
Nov 19 2013
Mar 24 2014
Feb 21 2014
Jan 4 2014
joergen 2
It can't hurt to repeat it occasionally... for all UM2 users, pour the watered-down wood glue onto a clean glass bed, spread it, and set your bed to 70C until the PMA wood glue is nicely dried.
