I will not say that my expectations are unrealistic. I am aware of the limitations in FDM printing. But it is depressing to see other people with a far cheaper machine make faster and better prints. And yes I know you cant compare apples whit oranges.
The first 100mm from the bottom, the layer precision is "in my opinion" really bad. Then it gets as "expected" towards the top.
The Pva is only used for the first 10mm so that shouldn't be and factor.
Rods have just been checked for play and realigned according to specifications. whit no difference.
Other things that have been tested:
Bed tempter on/off.
Z-axle have been tested.
Maximum head movement have been tested.
Diffrent Cura profiles. Both stock and item specified.
Diffrent print tempters, have been tested. to make sure its not under-extruding.
Diffrent filement have been tested.
Different item orientation.
Different models (Some have more than others "not same z-height" but its always there. Unless its and item under 50x50x50 mm then it's fine)
Nozzle swap.
ahoeben 1,987
Perhaps if you add some images, we can get an idea if the prints do indeed look like shit, if your S5 is underperforming, or if perhaps you have certain expectations that might not be realistic for this type of printer. At this point we simply can't tell.
