Shoot, I completely forgot that bit of info. This is for the Ultimaker S3.
I have not adjusted the buildplate scews at all from the factory, but I did measure to make sure it is still at the 14mm gap.
I also did check for disconnected wires at the sensor board inside the print head, but haven't checked with a meter because I don't know enough about the sensor to know what I should be looking for.
I think I'll try resetting the cable into the print head and check the continuity to the sensor while I have everything opened up.
Enigma_M4 77
first, it would be good to know which printer you have.
There are some posts relating to auto leveling problems with the UM3, but they may also be valid for the S5, for example:
or
So, checking the cables of the capacitive sensor would be a good first step. I also heard that fan cables running across the capacitive sensor or pinched cables can cause trouble, so its worth checking.
Regards
