There's a test-version of the Sidebar GUI plugin in this thread:
1
Awesome! You really have made my day 🙂 I haven't tested everything, but switching between the settings tabs when using 4 print heads is now really quick, and makes so much difference. Many thanks.
Tested the tree structure on a large dome shaped structure, it worked well, structure looked much better than previous, thanks.
Only comment is that it generated a single structure for both side where it may have been better to generate two trees one each side which would have been a bit quicker.
That said it was much better as the structure was further away from the model so easier to remove and less PVA strings getting into the nylon/CF material.
Edited by mrthomasbarnard
Thank you all that helped us test Ultimaker Cura 4.7 Beta. With your help we've been able to release the stable version. You can read more about it via this thread where we just announced it.
On 8/7/2020 at 9:12 PM, WesleyFreitas said:Olá, gostaria que tivesse perfil para a artillery sidewinder x1.
[translation from portuguese: Hello, I wish you had a profile for the sidewinder x1 artillery.]
I've yet to get 4.7 or 4.7 Beta to load a single STL file without crashing immediately so can't comment of any of the actual feature changes. I gather this is because the config parser was changed and won't accept an equals sign in any line in the startup GCode for a printer even if it's in the comments required for OctoLapse!
I hope Ultimaker have flagged this a priority to fix. At the moment, I'm still using 4.6.2 because it's stable and 4.7 obviously isn't.
That’s a bug that happens if you have one or more = signs in your start gcode snippet. It has been fixed in version 4.7.1, which will likely be released early next week.
gr5 1,517
@WesleyFreitas - sorry this is the english section of the forum. Portuguese only allowed over here:
https://community.ultimaker.com/forum/129-other-languages/
So Cura is made by Ultimaker for free. sidewinder is a competitor. But if they create a profile (or if you do) and submit it to the cura team they will include it in a future release of Cura. Maybe ask the sidewinder people to do this for you?
DivingDuck 59
Size of Print setting panel.
The panel window covers the Action panel when the main window isn't full size. There is an adjustment in high but it looks like you forgot to subtract the hight for the Action panel.
Maybe worth to correct before releasing the official version.Edit:
I just recognize, it's possible to adjust this manual. Maybe worth having this adjusted automatically.
