Still trying to get the firmware uploaded. Im hearing that the Arduino ide sometimes has problems with the Arduinos due to the braudrate connection and some other things. Theres the timeout or authorization denied. Ill look more into it.
On 11/24/2020 at 6:00 AM, gr5 said:Anyway to answer your question - just hook it up - you'll be fine. If the power supply can't deliver enough power it will just shut down when you turn on the heated bed. Nothing will get damaged. It just won't work.
On another note, I believe the part when the printer shutoff from heating the bed was maybe what you said before. The bed with 19v power supply would have 1.805 ohms with 200W and 10.52 A. Would regular marlin have the option with the budget hotbed or is that only with tinkermarlin? Also, isn't tinkermarlin only for upgraded boards like UM2 and UMO+?
22
17
17
12
Popular Days
Nov 18
18
Nov 20
9
Nov 15
7
Nov 24
4
Torgeir 22 posts
Juliogdiana 17 posts
3dprntz 17 posts
gr5 12 posts
Popular Days
Nov 18 2020
Nov 20 2020
Nov 15 2020
Nov 24 2020
Popular Posts
Juliogdiana
Got the printer fully working now with ultipanel controller, hot end temperature works perfect with amplifier e3d pt100 board, resistor R23 cut and firmware with sensor 20, same as um2. I
Torgeir
Just checked your possible choice of temperature sensors, -and a PT100 with a 4.7 Kohm is possible to use! Here it is: Good luck. Thanks Torgeir
gr5
Almost surely because you need to add the 4.7k pullup resistor. I think using the thermistor is a great solution. The pt100 isn't more accurate but it can handle higher temps. Thermistors get damag
Posted Images
gr5 2,184
I strongly recommend you don't mess with the bootloader. It may seem like it's gone but this is a common thing with arduinos - it seems like the bootloader is gone but it isn't. I have spent many frustrating hours with arduinos rebooting 1 second after starting compile, rebooting arduino 2 seconds after starting compile, etc. sometimes that trick works. Sometimes it doesn't. If it *looks* like it loaded a new firmware then it did. Either it works 100% or it works 0%. There is no in between where the progress bar gets to 100% but it didn't work. If the progress gets to 100% then it loaded properly.
the arduino IDE works better at loading a new firmware than the ultimaker GUI. The Ultimaker GUI doesn't seem to like certain COM numbers (e.g. COM3 through COM10 seems to work but sometimes my arduino is at COM13).
